Tool Talk Discussion Forum
Westinghouse welder NO 9-B-5101-P1
Cranbrook tract
07-23-2007 14:47:48
I found this old welder it is mounted on a cradle and is was powered by a small gas engine, belt drive. the gas motor is gone but the welder is not froze, still turns. can some one tell me any thing about this, is it wioth trying to get it going again and what size HP will I need to make it run and what can it weld ??
Could i just pull it apart and take a wire brush to it, coil and brushes, grease the bearing ??
135 Fan
07-23-2007 20:08:43
 Re: Westinghouse welder NO 9-B-5101-P1 in reply to Cranbrook tractor, 07-23-2007 14:47:48
Try to see if there is a name plate with horsepower or at least the amp rating and then you can better decide how much HP it will need. Dave
