Tool Talk Discussion Forum
Hot Tub (Pump only)
Tony6
07-20-2007 08:22:16
I am thinking of upgrading my 1 hp 115v pump to 1.5hp 240 v. I currently have a gfi 20amp breaker on the main panel.Should I change the gfi to a standard 240 breaker and try to pull a fourth 12 ga wire through (50 feet of 1/2" conduit). I will then need a 20amp GFI breaker (difficult to find and seem to be expensive) at the tub.The alternative would be to run a subpanel at the tub with new 6/3wg and hook up a Homeline 50amp panel,but this may be over kill. Any suggestions as to best way to proceed
Ryan - WI
07-21-2007 05:00:41
 Re: Hot Tub (Pump only) in reply to Tony6, 07-20-2007 08:22:16
I did mine last year and I believe you are required to have the shut off by the tub. It must be at least 5 feet away though. You can get a kit with the breaker and the box for around $60.
