Tool Talk Discussion Forum
Snap ring pliers
TimWafer
07-17-2007 11:44:27
What do you guys use on snap rings in the 2�to 4� range? Both internal and external. I had KD screw type that was barley big enough but broke it recently. Looking for something to replace it with but most of them are too wimpy. About the biggest pliers I see seem to be 16�. How big of a ring will they handle?
Thanks
Tim
JT@KY
07-19-2007 02:54:22
 Re: Snap ring pliers in reply to TimWafer, 07-17-2007 11:44:27
NAPA will usually warranty all the K-D stuff,I've warrantied all kinds of K-D's with them whether I bought them there or not. Just a thought that might save you some $$$
dobber
07-18-2007 10:14:14
Owatonna Tool Company or check some surplus tool places or military surplus places also. I bought a big ratcheting type at a military surplus store.
www.otctools.com
Hobo,NC
07-17-2007 18:58:45
A local tool dealer sometime bask was going out of business and had a great big pair that was made by Channel lock that I had had my eyes on. he wanted $45 or 50 for'em (listed for a 100 or so). I should have got them but did not. I had made a tool to remove the rings on the outboard drive units that worked good, made out of tool steel but the steel was free at the time. I just installed the clutch pack On a Kubota GST and let me tell ya that 6" snap ring was about as tuff as they get.
my Ho-made set would not touch it. I browed a pair made by snap-on and I got it but . So here i am with 3 of 400 in snap ring pliers (Mac and Matco's) and going to have to spend 3 or 400 more for a Snap-on set. The Snapper set did impress me for their size it handled that bad arse bota ring.
NC Wayne
07-17-2007 17:44:26
Did some checking around a few years back and the ones like your talking about were the largest we could find anywhere, and we got in Thomas register and called ALOT of places. Dad has a set he got back in the 70's that are about 20 inches long and just larger overall than the 16 inch ones. Unfortunately he doesn't remember where they came from and like the smaller 16" we've got they have no name or info on them. As for the largest ring I routinely take out an internal ring with mine that's about 8" in diameter. It's streching the capacity a bit I think because of the thickness/width/stiffness of the ring but it does the job OK. Personally I wouldn't want to try anything any larger than that with them.
oldrustycars
07-17-2007 15:05:47
I finally broke down and bought Mac Tools biggest set of snap ring pliers. they do internal and external, and I always have the correct size now. EXCEPT for the tiny rings on chainsaw wrist pins, I bought a few for those.
glennster
07-17-2007 14:26:43
napa has a heavy duty combination snap ring pliers set, part number ser 2012, handles internal rings 2-7/16 to 3-1/2 , external from 1-1/2 to 4 "., also try part number ser 3152, extra large convertible fits 1-1/2 to 4". for big external rings try bk 775-9043 brake retainer spring remover, for gm x-bodys, also s-10 and s-15 trucks and 4wd trucks
TimWafer
07-18-2007 05:48:17
 Re: Snap ring pliers in reply to glennster, 07-17-2007 14:26:43
The 2012 pair looks just like the KD ones that I had before. Imagine thats who makes these.They usually did the job. Actually all I broke was the screw that holds the tip in place but then the clamp and tip went flying and I couldnt find it. Wonder if you can possibly buy parts for it. I could make new tips out of allen wrenches. Need the little clamp though.
glennster
07-18-2007 05:52:16
 Re: Snap ring pliers in reply to TimWafer, 07-18-2007 05:48:17
napa has the repair kits and extra tips available too. check their tool and equipment catalog. should have somethin to fit.
TimV
07-17-2007 11:59:45
Tim: Can't exactly answer your question, but I'd be interested in hearing what others have to say. Just ran into two big, thick, strong snap rings stuck way down (about 8") inside the prop shaft housing on an Evinrude outboard motor. Used (and broke or twisted) several sets of pliers, including a Snap-on set, a MAC set, and a few others. Ended up getting them with a big set from OTC, but only after I welded up a collar (kind of like a flattened "O") out of steel flat stock to fit over them, and even then they twisted something fierce, to the point that the handles were overlapped more than 2" before the rings compressed enough to be withdrawn. Sure would like a better set, but couldn't find one.
