Tool Talk Discussion Forum
O.T Briggs Stratton Quantam engine
Dave F.
07-16-2007 13:13:56
The short of an long story,Wife hits item in yard. Replaced flywheel key & new blade engine starts has good power but vibrates excessively(bent crankshaft) Took mower to a fellow that said he could straighten shaft. get mower back it will run but at low engine speed, would stall out in high grass. Details of mower. Its a fixed throttle type, has primer bulb on carb. No choke,fixed adjustments on carb no idle/mixture screws. when trying to advance the throttle/gov linkage the engine will rev up slightly maybe 100 rpm. could something come loose inside the carb. I am sure they had jostled the engine around to straighten the crank they said they used a press to straighten it any help would be greatly appreciated, this mower is selfpropelled & only a year old I would hate to junk it. Thanks Dave F.
buickanddeere
07-20-2007 18:01:26
 Re: O.T Briggs Stratton Quantam engine in reply to Dave F., 07-16-2007 13:13:56
New mower is less that $200.00 Old mowers are not worth repairing. A carb kit, oil change, new blade, new muffler and new tires cost as much as a new machine.
JeffL-TN
07-17-2007 13:28:41
The crank is still bent. Tear it down you'll probably find wear marks on crank,rod, block etc.
Kevin (FL)
07-16-2007 17:20:39
Dave,
We have a couple of those--both 5 HP vertical shaft and both pretty much worn out, smoking and needing rings if not junking. A couple of maybe things--make sure the linkage cable hasn't slipped past the normal clamping point so you're not getting the full "stroke" of the throttle adjustment. 2nd, I'm told by a local fellow who does alot of mower repairs, that those engines have a plastic governor gear that's easily broken or maybe one tooth is cracked/broken. Could be that happened when they were beating on the crank. As a last resort, I adjusted the idle screw on ours when the governor wasn't working properly. This provides a higher throttle setting but doesn't help with the "droop factor" in thick grass from not having a governor.
