The short answer. it shouldn't be a problem for just a couple of cedar posts. Your chainsaw won't notice. The long answer. How rough on the chainsaw? Depends on the saw, depends on the wood, depends on the chain. The saw: milling lumber takes power. The bigger the saw, the better, but even small chainsaws can mill small jobs. I mill lumber (hobbiest) with a a fairly large saw, a Stihl 044 and an Alaskan mill. Ripping lumber up to 28 inches wide is not a problem. But I have also used a small limbing saw. The wood: soft, wet woods mill easier than dry hard wood (e.g. oak). The cedar posts will probably mill fairly easily. The chain: for a small job, just a couple of planks, for example, a regular chain will work. Yeah, it makes a lot of long shavings, but you can remove the chain cover if you feel it is causing problems. For wider or longer boards, or bigger jobs, use a ripping chain. They can be expensive, but you can make your own by refiling an old chain so the teeth are near perpendicular, within 10 degrees. You can make fancier ripping chains by removing teeth between pairs, but it makes for rougher lumber. It takes less power though. Oh, and make sure those teeth are razor sharp. The question implied, but not stated, is, how hard is it on you? Physically, it depends on how well you made your chain. If those teeth are uniform and the rakers the same height, it's a breeze. Mentally, it depends on how much you trust others with your tools. I don't loan my tools. But, if you like your neighbor, milling wood is a fun group activity. Well, that is probably more than you wanted to know. Neal
