Tool Talk Discussion Forum
armature growler
ldj
07-09-2007 15:05:51
I just got an old armature growler. I haven't saw one since I was a kid. No name on it but it has model # 440. It has 2 leads/probes, a red and a black one. Since I don't know anything about it I am leery of it. I put an armature on it and turned it on. I did read in a net search not to turn it on without a armature in it. I measure ac between the 2 probes and have 120v. When you touch them together the light bulb comes on and you get a spark.Isn't that kinda dangerous? I can't find out a lot about it on the web. Anyone know where I can find out about this?
L.D.
Bob
07-09-2007 15:24:59
 Re: armature growler in reply to ldj, 07-09-2007 15:05:51
First the "growler" function...
You hold an iron strip (hacksaw blade) on top of the laminations, parallel to the armature's shaft axis, and slowly rotate the armature. If there is a shorted winding, the hacksaw blade will vibrate/buzz/growl as the area of the laminations involved with the shorted winding pases.
Now, on to the test leads.
They are used to detect leakage from the windings/commutator bars to the steel parts of the armature. There is an indicator light that will begine to glow if there is a short/leakage to ground.
The 120-Volts may be either "live" from the wall socket (through the lamp filament, IF the unit has a polarized plug, AND is wired properly) OR isolated from ground by an extra winding on the growler's core. (IF the unit has a polarized plug, and is wired properly, the BLACK test lead will be "ground", and the red test lead will be 120 VAC, fed though the indicator lamp.)
Either way, it will give a damn nasty shock if you get on the wrong side of it, or it could even kill you.
I don't think these things would be "OHSA-approved", if manufactured today!
