Tool Talk Discussion Forum
Installing PT Fence Posts in Gravel Ground
burnetma
07-09-2007 07:17:08
I would like to build a high tensile fence on a 2 acre piece of river bottom gravel ground. I have a bunch of 6, 8 & 10 inch diameter posts left over from a previous install done by a contractor on sandy loam & pea gravel. My question is: Should I pound the posts or auger them? I can do either with rental equipment and my 65 hp tractor I have set up for skid steer attachments. I just am not sure if pounding will work on this gravel ground.
Dave Sherburne NY
07-10-2007 12:17:58
 Re: Installing PT Fence Posts in Gravel Ground in reply to burnetma, 07-09-2007 07:17:08
Pound them in it will work just fine and they will be tight when your done. Unlike trying to get the loose gravel out of the hole from drilling.
burnetma
07-11-2007 17:40:20
 Re: Installing PT Fence Posts in Gravel Ground in reply to Dave Sherburne NY, 07-10-2007 12:17:58
Dave,
Thank you for the response. I will give it a try in the next couple of weeks.
Mark
