If you have a door on every bay, you need to do something different with _one_ door - or make one a wall. The rest can all slide on the same track. You just might need to push 3 doors out of your way to open that farthest door. :) Like I said, one roll up door you use the most, & the rest sliders, run the track past the roll up door & you only need single track. All doors on the same track. Now, this is a pain if you want access to all bays all the time, but if you want cheap doors with limited access to 3 of the bays, do it like this: Slider rollup slider slider slider slider Run the track across all 6 bays. You can roll the 1st door to the right for access. Use the roll up for access to the 2nd door (of leave it a wall if you don't need doors for all 6). Roll the third door to the left for access. The 2 far doors, you roll the door(s) ahead of it to the left to get to it. Again, if you want a lot of access to all the bays, then this gets pretty busy pushing doors out of your way, so depends on your needs. But a combo of sliders, roll up, or wall can give you pretty cheap doors on a single shared track. --->Paul
