Tool Talk Discussion Forum
5 cubic foot cement mixer
ray_woods
07-08-2007 13:35:35
I was given one. Only thing I need at the moment is a 8x12'slab. Thats a yard and a half. Any one ever pour a small slab with one?
NE IA Dave
07-09-2007 21:56:35
 Re: 5 cubic foot cement mixer in reply to ray_woods, 07-08-2007 13:35:35
Check with your redi mix company first. Bag cement prices @ a 6 bag mix makes out of the truck cheaper than your first thought.
I have three mixers of different sizes, and unless we are mixing mason cement we do not even consider mixing ourselves. There is alot of hastle getting the cement---most we get nowdays has large lumps in it as it has set for years at the lumber yard. Hauling gravel & sand & cement takes time, and is a pain usualy. I always have to add the labor costs also. Most times we have something over on the cement plant manager that we can threaten them with to knock off the small load charges, and if you pour late afternoon that may conflict with happy hour, the drivers will give you a lot of extra cement so they do not have to make a return trip. We get alot of small pours with out charge at all if we can pour at the correct time with over run concrete from big pours. It is very supprising what fellow man will do as a favor if you treat them well in all dealings.
ray_woods
07-08-2007 18:02:03
Thanks for all the replies. Very encouraging to read.
RayP(MI)
07-08-2007 17:56:11
Heck, back around '49 - '50, my dad poured the whole foundations and walls for a barn, as well as flooring, stalls and concrete manger. Walls are 1 foot thick, 8 feet high, and the barn is 35 feet by 60 feet. Did I mention he hauled the gravel from the back of the farm on an old wooden wheeled wagon, and screened it with a homemade screening rig made from an old washmachine motor? Concrete today is as good as it was then. You can do that job easy! Your extension office probably has literature telling proper proportions, etc. But then a phone call to the local ready mix plant is far easier!
suptscottyb
07-08-2007 16:44:32
I think the mix is 3, 2, 1. 3 parts sand and gravel. 2 parts water. 1 part portland cement.
Just pour in sections you can handle. If you are not a "finisher" start small, edge all sides and pour tomorrow's mud up against today's.
Red Dave
07-08-2007 16:57:37
 Re: 5 cubic foot cement mixer in reply to suptscottyb, 07-08-2007 16:44:32
It's 3 parts aggregate (stone) 2 parts sand and 1 part Portland cement by volume. Add water to proper consistancy, but keep it as dry as it can be worked for maximun strength. Too wet weakens the concrete. Can be varied somewhat to suit the application. We used to use a 6 cubic foot mixer. 3 Cubic feet of stone, 2 cubic feet of sand and 1 cubic foot of portland cement.
2 parts water is way too much.
Rod in Smiths Falls, ON
07-08-2007 16:29:53
The local quarry has a pile of sand/gravel mix they call concrete mix. All you add is Portland and water. It sells for the same price as the other stuff and greatly simplifies the mixing process. I think it's a five Imperial gallon pail of water and fifty shovels of gravel for a bag of Portland.
This recipe was told to me by a farmer who did a lot of concrete work for his new dairy barn using a p.t.o. mixer.
Greg_Ky
07-08-2007 14:36:13
That wont be any big deal, the main thing is to get the correct ratio of stone, sand,and cement.
third party image
Stan in Oly, WA
07-08-2007 14:35:44
Hi Ray,
My brother-in-law and I poured more square footage than that in a day easily enough, but it was sidewalk and patio sections---no section over 4' wide, as I remember. I've poured patio sections over half that big by myself several times, but I generally tried to keep it to manageable proportions when I could. All that shovelling, and hauling, and screeding, and finishing, and cleanup gets exhausting.
I have a 5 cu ft mixer I bought 30+ years ago which has mixed hundreds of yards of concrete (and mortar.) On any job large enough to justify the time I used to try to knock together a platform for it to stand on so that I could tip it vertically enough to get a clean pour into a 6' wheelbarrow. A few years ago I fabricated some entensions that bolt on to the frame so that it stands about 8" higher than they way it was built.
The ideal arrangement for mixing is to have the mixer next to the sand and gravel and be standing on something high enough so that you don't have to lift the shovel too high to toss the stuff into the mixer. The wheelbarrow is loaded on the other side. You might think you want to set up your pour so that you can dispense with the wheelbarrow and dump the mixer directly into the form, but moving the mud along the ground is actually much harder than wheeling it even a short distance.
If you end up mixing much concrete with a mixer you'll come to realize that it makes sense to find a way to reduce every element to the least possible effort. There's a sort of primitive satisfaction involved in doing it the hard way, but it doesn't take long before you find that you're old much sooner than you had to be. That's been my experience, anyway.
All the best, Stan
