Tool Talk Discussion Forum
Water leak
supera3
07-07-2007 12:36:05
I have a water leak! Two gal/min 2500' 2" plastic.Big dry here in Ky. open pasture no greener grass or wet spots. What to do? Thanks in advance. gary
supera3
07-09-2007 15:26:16
 Re: Water leak in reply to supera3, 07-07-2007 12:36:05
Just an update. City came down with headphones & probed the line, located clorine 50'away on 3rd neighbor's. Dug holes allday no leak yet,but friend's farm looks like God' little Acre.I'm Tyty.
Bill-KCKs
07-08-2007 06:26:05
Somebody, maybe the water utility, has to have a leak detector. They work very well, using the sound of the leak. Attach a transducer to each end of the line, measure the distance between transducers, and the computer pinpoints the leak. There may be newer technology.
Here's a link I just found to one company. I know NOTHING about them, just found them on Google...
Bob85355
07-08-2007 00:34:47
I have about 2500feet of 1.25 plastic and have had several leaks over the past 15 years. All have been at joints. If you used 10 ft pipe then you could take a 10 ft pole, or a another pipe, and probe at 10 ft intervals.
Having said that, I"ve seen probably a dozen leaking pipe situations and all have resulted in surface water eventually. Unless you"re on a sand bed, you should see water. I worked at a place next to a sandy dry river and you could pour water on the ground for a month and never get a puddle.
Yes, please let us know how you resolve it.
Bob
Central Arizona
MBU
07-08-2007 00:06:12
supera3,
Only way I know how to find it is by elimination.
Go about 1/2 the length of the water line and install a valve. Shut the valve and check water meter. If still leaking then the problem is between the meter and the newly installed valve. If it's not leaking then the leak is between the newly installed valve and the end of the line. Keep repeating the 1/2 length elimination and you'll soon find the leak - may take a dozen valves though. Lowe's or similar has some plastic ball values that cost around $8.00 for a 2-inch size.
To speed things up a bit you might look for places that a leak would likely occur. For example, if a tree is growing near the water line a root may have broken the line a slight bit. Or if there is a hard connection (line is connected to a concrete wall etc.) where a shift in earth may have caused the line to break. Or�if a leak was just repaired it is very likely that the new leak is nearby as the pipe was most likely disturbed.
When you find the leak and get everything repaired go back to each valve you installed and put in a plastic pipe riser before they are backfilled. This way you'll save lots of time and expense the next time a leak appears. On all new water lines on my ranch I now install valves every 200 feet. Leaks happen!
On other thing you might try is take a small ripper and pull it along the top of the water line. You might just get lucky and find a wet spot.
Good luck and please post back on how you found the leak...we all will be in your position at some time.
Greg_Ky
07-07-2007 13:56:42
I take it that you have city water. If you do contact the water department and see if they have an ultrasonic leak detector that they could use to find the leak for you.
supera3
07-07-2007 13:46:52
NOPE was not that smart back then!
Greg_Ky
07-07-2007 12:48:54
Do you by any chance have a tracer wire buried with it?
third party image
