Hood and muffler removal of 1947 John Deere A
Harvey Warren
06-03-2001 16:03:04
Does anyone have any information on hood removal on 1947 John Deere A tractor and removal of old muffler and installation of new muffler and radiator hoses. Also, any info helpful on sliding wheels on rear axle.
Thank you.
Keith
06-06-2001 16:25:37
 Re: Hood and muffler removal of 1947 John Deere A in reply to Harvey Warren, 06-03-2001 16:03:04
In order to remove the hood you'll need to first remove the steering wheel from the shaft. Then you'll need to remove the sheet metal cover over the steering gear at the top of front column and the grill panels. This will give you access to a bearing housing plate which you'll need to remove along with the bearing inside. Also remove the cover from the top of the pedestal note how the steering shaft aligns with the vertical shaft to the wheels. The shaft with the rear bearing on it can then be removed through the front of the pedestal. At this point you can then remove all the bolts holding the hood down so that you can lift the hood straight up and over the muffler and the air intake. At that point you'll finally have access the four bolts which hold the muffler on. After doing this process you understand why you see so many old deeres with the sheet metal around the muffler hole cut away so they could replace the muffler without having to take all that other stuff off. Hope this helps.
