trucker 40
07-03-2007 20:08:25
Re: Welding cast in reply to Johndeere, 07-02-2007 07:43:41
Ive brazed it,used nickel rod,used 7018,but You can weld it with a mig most likely.What I do is take a grinder to it and if it sparks like a piece of steel you can mig weld it.You want to grind a groove in it,then use short welds,more than a tack,like about 1/2 inch,might not hurt to heat it some with a torch first.Use the torch in a spiral from the center out,not real hot,but hot enough you dont want to touch it.Weld a little,clean with a wire brush,keep going until you are done.Once you start you cant stop,but you have to go kind of slow.If its thin you want to try and fill your groove in one pass.When you are done you want your weld to be only a little higher than the surface of your part,and I think I would heat it a little with a torch afterwards,to kind of make it the same heat.I would be easy on the torch,it dont take much.Its been a while since I did this,but I bolted it together if I can,then weld it,then once its cooled down to where I feel like its not going to crack,I grind the surface a little to kind of flatten the weld on top,I think this makes it stronger. The bad part of doing it like this is it might crack,but it might crack if you use a torch.I bought an old H that had the rear housing cracked underneath about 4 years ago.It was leaking,and as I was grinding on it I saw it was real thin metal.I can braze but I need it to be flat,not overhead,so I got out the mig and welded it up,but I did just like I wrote above,and it was a long crack,and since my overhead weld was not looking that good,I stopped a lot and ground it flat.It took a couple of hours,but it still aint broke,and I use the H for a bulldozer sometimes as it has a loader on it.Worst thing about the welding was I had to grind all that brass off,then weld,then grind down the weld.I had it crack on me as I was doing it,but I think it was mostly where I built it up in a couple of places as I was trying to smooth out my weld.Best way is to not use any more weld than you need to,keep going,heat is allright but it needs to be even.The reason I say heat it up with a torch is that it kind of spreads out the stress you are going to put it through by welding it,but you dont want to stress it anymore than it needs,if you get what I mean.Ive welded a lot,just not cast,and have a kind of instinct for how hot it needs to be.If its a long weld like the one I made,you might need to heat it some in front of your weld as you go with a torch,but as I tried to say in this long drawn out answer is too much heat can make it crack,so can a lot of stress.However I like the mig the best of the ways I did it.Just my opinion,and it might not be the best one to listen too.I dont use a torch to weld much,never did.I have used 7018 with no problem,but you want to do everything I said before and peen the weld with the pointy side of a chipping hammer every half inch of weld.Clean with a wire brush before welding again,it has to be as clean as you can get it,might even want to grind it before you weld again.
