Tool Talk Discussion Forum
2 cycle eng.
Billpa
07-01-2007 14:35:34
can you use dry gas in a two cycle engine ?
Bob - MI
07-02-2007 11:20:53
 Re: 2 cycle eng. in reply to Billpa, 07-01-2007 14:35:34
Try using Sea Foam. It was originally designed for marine applications. I am guessing that since you have an outboard setup with a 90 gallon tank you have a late model motor(s) with oil injection. The other choice for marine fuel rejuvenation is PRI-G.
I have a large tank on my boat and I don"t get enough hours on it to keep the fuel fresh as I would like it. I have been using Sea Foam on a regular basis and have had no problems. PRI-G was suggested by the West Marine dealer one year when I had 2-year old fuel(long story why I couldn"t get on the lake). Put the suggested amount in and had no problems at all.
Good luck.
Davis In SC
07-01-2007 18:10:06
I would hesitate to use it in a 2-stroke. The alcohol can dilute the lubricity of the oil mix.
Tim Casbolt
07-01-2007 17:35:38
why would you want to put dry gas in a 2-cycle engine? If the gas gets old from non-use and takes on moisture, dump it out and put in fresh gas.
billpa
07-02-2007 06:11:08
 Re: 2 cycle eng. in reply to Tim Casbolt, 07-01-2007 17:35:38
#1 it is in a boat with a 30 gal tank thats $ 90.00 worth of gas thats a little tough to swallow #2 thanks for all the replies Bill
TimV
07-01-2007 19:51:03
Tim: It's very common in engines that are run in cold weather, such as snowmobiles. Many sledders (including myself) carry a bottle with them, as even fresh gas can have water, and it doesn't take much to freeze up a fuel system, which can make for a long, cold walk home.
TimV
07-01-2007 14:48:50
Billpa: Making the obvious assumption that you're asking whether or not you can add dry gas to your regular 2-cycle mix, the answer is yes. Don't add too much, however--2-cycles tend to be pickier than 4-strokes with regard to what they like to drink, and too much can cause starting and running problems.
Farmall MD
07-01-2007 14:48:40
Sure, why not? There is still oil in gas to lube parts. Didn't make it over today. Doug
