Tool Talk Discussion Forum
Cordless drill decision
Bernoulli/OR
06-30-2007 16:41:48
I'm presently in Australia (230VAC 50 Hz). I have a Porter Cable 12V Cordless drill. I bought two pairs of 12V battery rebuilds - none worked. Looking for a replacement on Amazon, I saw several reviews of the Porter Cable charger that said it was worthless. I can't find a generic charger. So..., I could buy another P-C charger, either 12V or 9.6-19V or another battery (original P-C), or forget the whole thing and get a new Panasonic NIMh 15.6. The charger will be operated off a transformer. Has anyone had any experience with the P-C batteries, chargers or the Panasonic? Thanks!
Bernoulli/OR
07-02-2007 18:27:05
 Re: Cordless drill decision in reply to Bernoulli/OR, 06-30-2007 16:41:48
The Ryobi idea is a good one, but the batteries I have are of the slide in contact design rather than the male design. The transformers I have are indeed heavy, so I must have the right ones (I'm electrically challenged). Thanks
Vern-MI
07-03-2007 03:56:33
 Re: Cordless drill decision in reply to Bernoulli/OR, 07-02-2007 18:27:05
The Ryobi CD125, model 4400006, is the slide contact design with the third temperature contact not the spade and lug design of the later models. It is a 120 VAC, 60 cycle charger however.
rp3
07-01-2007 12:08:09
"The charger will be operated off a transformer"
Be sure it's a real transformer and not one of those rectifier convertors. It should be heavy like it's filled with iron.
If it's not a transformer then the charger won't work and can even be damaged by it.
Vern-MI
07-01-2007 04:56:19
I had one of those Magnaquench drills and it too had a bad charger. I bought a Ryobi 12 volt charger for 17 bucks and it worked just fine. I'm done with the drill and if you were closer I would ship the charger to you free but I don't think I want to ship it half way round the world.
msb
06-30-2007 18:02:29
Since its 12 volt and if worse comes to worse, try hooking it up to your car battery.
KEB
07-01-2007 13:57:43
 Re: Cordless drill decision - DON'T in reply to msb, 06-30-2007 18:02:29
DO NOT, under any circumstances, hook a cordless tool battery to an automobile battery or charger, even if the voltage rating is the same. NiCad and NiMH batterys charge at a constant current, not at a constant voltage like a lead acid battery. Whatever charger you use for a cordless tool battery must be current limited - connecting a NiCad bettery to a large current source such as a car battery will rapidly result in an overheated and possibly exploding NiCad.
Most cheap chargers with a wall-wart transformer depend on the inherent resistance of the transformer to limit charge current. More elaborate ones electronically limit current based on battery state of charge and temperature.
Keith
msb
07-01-2007 19:39:48
 Re: Cordless drill decision - DON'T in reply to KEB, 07-01-2007 13:57:43
Should have said remove the old battery first.That Will work.
