I got to have some real fun today- re wireing my trailer. It wasn't a badjob, but the old wireing sure was! It was spliced here, spliced there, and to top it all off it was about 5' too long so the guy just criss-crossed the wires under the trailer to take up the extra, instead of cutting it to length!!I got a new harness from TSC and put it on it's side to work on it. I had to reweld the back upright on that the light was mounted to- just the wood was holding it on so that side didn't work. After running all the new wires and hooking it up, everything worked except the running lights- Turns out that was the end on my truck, that terminal was full fo corrosion but I had a new lead so I put that on. Now one side had the running light but not the side I welded on. Had a bad connection in there as well I guess, so I ended up buying a new light for that side and now the lights are better than ever. Heck, even my magnetic trailer lights work better now with the new lead on my truck... I coated all the connnections with some dielectric grease to keep the corrosion down some, still gotta tape up the splices by the lights. Some time I want to put a set of lights onto one of our hay wagons that we use on a regular basis for hauling other stuff. The running gear is 40-50+ years old but still goes down the highway 65MPH straight as ever, loaded or empty. Has nice heavy 16" truck tires on it too, so it's a good road worthy wagon... just needs some more permanent lights... Donovan from Wisconsin
