Being a Miller fan, I'd have to say "not much". I just used one of these for 3 days and I can tell you it ain't no Miller. I'm not bashing lincoln, I just prefer the Miller's because they are snappier running. The price would depend upon the type and number of options as well as the power plant. If it is fully loaded CC/CV with the 120/240 volt aux power outlets and has the Onan engine, they go on the used market for around $1000 to $1500 with marginal low hours as this one has. If it has the Kohler engine (many problems with these) you'd be lucky to get $300 to $500 for it. I don't recall if they made these with the Brigs engine or not but if so, they would go between $800 and $1200 also depending on condition. (basing these prices on what I see buyers pay for these for at auctions as it is a good indication of true value price for the equipment) I'll be honest, I have never ran a Ranger 8 on CV so I can't say how they burn wire but they do lack spunk pushing stick electrodes on the CC side. Don't get me wrong, for occasional use such as light service work, they will suffice. If you're planning on doing any serious production work and are accustomed to using a hot running machine with a snappy arc, you will be disappointed in the performance of the ranger 8. Last I looked, new these are selling around $1800 to $2300 (once again depending on options and market location) Rule of thumb I use is this: If you are buying a used machine no matter how good the condition of it, paying any more than 50% of market retail is wasting your money. In most cases with a machine such as this, any brand, you will not get any type of warranty unless you purchased it from the dealer or can show proof of purchase from a dealer so you're on your own if it fails. Second part, you don't know how this machine was used even with the low hours. It could have been only used as a power generator or 90 of those hours could be from thawing pipes which kills the machines very quickly as does people who stick the rod fast to the work more than they run a bead. Be cautious of what you buy. It only takes a few minutes to disconnect the hour meter on equipment such as this and the unit may actually have 1000 or more hours on it. Check the entire machine out first. Run both stick and wire with to make sure it works properly. Check the AC/DC power outputs to make sure they are working properly. Use all of the welding ranges and settings too. Check the engine over real good. Onan's are big bucks to fix if they break. For the cost of a rebuild kit for an Onan and the time and effort you'll put into it, you can buy a whole new machine cheaper.
