Tool Talk Discussion Forum
dry concrete in a post hole?
sjh
06-28-2007 10:11:38
I have done this twice. The first was a porch. 5 years later dug post up to add a deck. Concrete never set. Second one is brother did it and the post sank on him. My question is, if you have done this have you ever dug it up and found the concrete set?
cj3b_jeep
06-29-2007 04:54:07
 Re: dry concrete in a post hole? in reply to sjh, 06-28-2007 10:11:38
Here in Ohio, at least in my county, the standard is to drill an 18" hold, 38" deep. Make a concrete pad in the bottom 8" thick. Set post on top, backfill and pack tightly. I do like the idea of pea gravel. If you set your posts with concrete around them, you're just asking for them to rot. For smaller jobs, I have set them in concrete, but I wrapped the post with tar paper beforehand.
Thunderr
06-28-2007 20:01:24
WELL DONE FAWTEEN! Thats the way it ought to be done, if only it could always be that good...And for fence posts the very best is gravel filled. Forget post rotting, hard to remove and useless concrete, or expensive rapid post mix.
Mr Bob
06-28-2007 19:59:36
I never set treated posts in concrete. I pour slag or crushed limestone around them and tamp it down hard with the top end of a spudbar. Here in Ohio, I've seen treated posts that were set in concrete rot off right at the top of the concrete. I've never yet known of any I've set over the years to have rotted off or come loose yet.
ldj
06-28-2007 19:20:02
No. But I put pea gravel in the hole. Works better than anything I ever used. Here in Tx when It gets dry and the ground cracks open, the pea gravel will work down an fill the void. With cement in the hole, when the ground cracks open there is nothing but a space between the cement and where ground pulled away, letting the post lean.
Midwest redneck
06-28-2007 13:18:13
What I did for my deck is....I used a Hilti hammer drill with a mixing bit to mix concrete in 5 gallon buckets and then I poured it in the holes. (works great, and you dont need a cement mixer)
souNdguy
06-28-2007 11:58:52
I like addingwater to the hole and give it a few mixing shots with the shovel.
For big piles.. I like to drop a pillow block.. or concrete pad block in the hole to prevent sinking.. etc..
Soundguy
jml755
06-28-2007 10:45:30
That is a common way to set posts. I've done it in the past and had mixed results, depending upon the moisture in the soil, time of year, etc. I've also poured wet concrete around the posts with mixed success. (Concrete sets up nice, but develops cracks at the corners where it's the thinnest.) Next pole barn I build will just have gravel or crushed concrete around the posts for drainage. You'll probably get dozens of different opinions on this. Should be interesting reading.
Fawteen
06-28-2007 12:23:41
 Re: dry concrete in a post hole? in reply to jml755, 06-28-2007 10:45:30
I'm with you. If you are in frost country, a "dry hole" is the best. Local frost line is considered to be 4 feet.
I've done two projects where any heaving would cause significant problems. I built a deck for a B&B, used 6x6 PT on the corners, down a minimum of 4 feet 5 if I could get it, poured a 4" thick pad in the bottom, set the post and wrapped it in plastic (theory is the frost will move the plastic, not the post) and backfilled it with well tamped screened gravel. Hasn't even twitched in 10 years.
Built a pole barn the same way, with the same results.
