Tool Talk Discussion Forum
pouring a post before a rain?
David Dardis
06-27-2007 10:10:41
Hello, I hope all is well. I wanted to cement posts in the ground for a small deck I'm building today. It's supposed to rain some later, should I cancel or go ahead. I was just going to dump dry concrete in the hole and forget about it. Maybe sprinkle a little water on the top if it doesn't rain. I did this on a deck in the front I built 15 years ago and it still looks new. If this were elevated, I might reconsider but it's only a few feet off the ground. If I cover the post holes with plastic, do you think it'll keep it from getting too soupy? I'll wait if you think it best but I'm just anxious to get this done. One other thing, I went 32" deep, does anybody know if that's good enough for N.E. Ohio? Actually, I only went 24" deep on the ones in the front but the ground is much harder. Thanks for your advice, I appreciate forums like this. Dave
paul
06-27-2007 11:12:54
 Re: pouring a post before a rain? in reply to David Dardis, 06-27-2007 10:10:41
Hard packed ground freezs deeper than soft ground, so you would want to go deeper in those areas, not shallower. The concrete needs to be below the frost line, or it may heave the posts up.
In my clay I don't fool with concrete around wood, tends to just make rotten posts, but I know it's code in some places. I'd prefer the post bolted on top of the concrete, or the concrete well below the soil line - as I'm sure you are doing. Concrete surrounding the wood near the soil line rots quickly 'here'.
--->Paul
David C Dardis
06-27-2007 12:02:04
 Re: pouring a post before a rain? in reply to paul, 06-27-2007 11:12:54
Well it stopped storming temporarily, time to get away from the computer between lightning strikes anyway. So Paul says harder ground freezes deeper? We just went through the winter from hell, if the 24" holes in the rock hard soil up front didn't heave the posts I guess the 32" deep holes in the soft soil will suffice? I maxed out the depth of the post hole digger, can't open the jaws any deeper unless I make the holes wider. One voice in my head says "do it right" the other one says "do it right now". And of course a third one is saying "take a nap". Ho-boy..
paul
06-27-2007 16:04:35
 Re: pouring a post before a rain? in reply to David C Dardis, 06-27-2007 12:02:04
I think I listen to the nap talking too much. ;)
You'll end up fine I'm sure. :)
--->Paul
David Dardis
06-27-2007 10:48:43
Looks like I might have to wait afterall. Our projected little shower just turned into a typhoon. Rain don't bother me, lightning does.
I guess I need to go 6" deeper anyway.
Thanks for your help folks.
Dave
cj3b_jeep
06-27-2007 10:33:56
Hi David, code for summit county is 38" w/8" of concrete.
J.C. IN AZ.
06-27-2007 15:04:20
 Re: pouring a post before a rain? in reply to cj3b_jeep, 06-27-2007 10:33:56
You guys in Colorado?
cj3b_jeep
06-28-2007 05:51:35
 Re: pouring a post before a rain? in reply to J.C. IN AZ., 06-27-2007 15:04:20
Summit county, northeast ohio
cj3b_jeep
06-27-2007 10:33:56
David Dardis
06-27-2007 10:30:03
Thanks John, that's the answer I wanted to hear!
JOHN HARMON
06-27-2007 10:21:58
Pour the dry crete in the hole and unless water would pool around the posts forget about it not setting up. The time to pour Concrete is when the ground is dry,when it gets wet it will pack around the post tight.
