Tool Talk Discussion Forum
Winches- need info
Jrry
06-27-2007 06:47:40
I need a 12 volt winch on my trailer. The only ones I see in the local phone book are Power Winches. I can get a 4000 lb for about $500. Any other suggustions? thanks
johndeeregene
06-27-2007 21:07:22
 Re: Winches- need info in reply to Jrry, 06-27-2007 06:47:40
what ever winch you decide to get, the most important is the size, an what it will pull. my advise in this area is. what ever size you decide go at least the next size bigger. i have a 10000 on mine, an i am goin to take it off an put a 17000 on instead. put 10000 on the car trailer. the best way to run it is to mount a battery on the trailer an run a power line from you battery on your vehicle an put a connection someplace beside your plug on your vehicle, i use welding lead with welder connectors plugs, then run a line from the battery on the trailer an put a connector on it, so when you plug in your trailer you just plug in the battery also, no problem with dead batterys, an when running the winch you have 2 batterys an a altenator running it. no problems in over 10 years now, running a winch like that
just my 2cents worth johndeeregene
kito169
06-27-2007 20:00:39
Warn winches are rated at pulling dead weight on the ground (sliding). I use a 3700 lb Warn it was $359 from TSC. I still haven't had to use the snatch block that I needed with my old one. It was from Sears.
Oldmax
06-27-2007 10:50:48
third party image
I built a HYD winch for mine from parts i had on hand .
MLP
06-27-2007 10:21:14
Try looking at Greg Smith Equipment. They have some very good buys.
I just got one of theirs. I have not got it mounted yet but it does look very rugged and well built.
CRUSADER
06-27-2007 10:15:12
I was at the Sam's Club in Abilene on Monday. They have a 10,000 pound winch for $367.00. Looks like it is a very good unit. Was interested in buying, but not sure how I would justify the purchase with Momma-San.
Jim
rockyhawaii
06-27-2007 21:26:17
 Re: Winches- need info in reply to CRUSADER, 06-27-2007 10:15:12
The winch at Sam's is a Champion. Chinese-made, but people that have them like them ok. For the money you could get a nice American-made Warn, and you'ed never wear it out.
CRUSADER
06-28-2007 05:10:23
 Re: Winches- need info in reply to rockyhawaii, 06-27-2007 21:26:17
Thanks for the info on the winch. I didn't look at it close enough to see where it was made at. It seems that the "Made In The USA" trademark that Sam Walton tried to promote has gone away just about the same time that he did.
Mike M
06-27-2007 09:11:49
I wasn't too thrilled about an electric winch because I figured I'd always have dead batteries.
I found a military winch and coupled it to a gas engine with a reduction built in and mounted this on the front of the trailer. It has worked well over the years and that engine has never failed to start. I keep stabil in it and even siphon and replace the gas once in awhile.I bought the engine new and it is a briggs and stratton 5hp I think. A hyd. drive system off the engine would be the only improvement I can think of as then I'd have reverse.
Roger in Iowa
06-27-2007 08:05:16
I use a Super Winch from Orschelin (similar to TSC) for lots less than $500. Can use a snatch block for increased power but the model X2 should work well. It is power in/power out without a clutch. Control is on winch.
Roger in Iowa
55 50
06-27-2007 08:49:02
 Re: Winches- need info in reply to Roger in Iowa, 06-27-2007 08:05:16
I have one just like that X2. Picked it up at an auction for $50 and it was brand new in the box!
old
06-27-2007 07:48:26
Habor fright, or nothern hyds both sell them plus a good number of other places. I would do a web search for them and see what you come up with
