Tool Talk Discussion Forum
Trailer Brakes
BOBM25
06-26-2007 08:57:50
I just bought a gooseneck trailer and the guy I bought from said it had air-over-hrdraulic brake system. He said it was pulled by a dump truck. I am only familiar with electric brakes. What can I do with this system to be able to pull the trailer with my 02 Chevy Silverado 2500HD? How much will it cost me? Thanks in advance.
guess who
06-29-2007 20:25:04
 Re: Trailer Brakes in reply to BOBM25, 06-26-2007 08:57:50
It should have a master cyl mounted on the front of the trailer and instead of having a helper or brake man sit back there they hook up a air cylinder that is powered from the trucks air brake systym. I would not have bought that trailer unless the price was right or you are going to resell it. I would look into changing the axles to ones with electric brakes all ready or sell it or get the right truck to pull it as it is.
Oldrustycars
06-27-2007 17:31:41
Convertring to electric brakes will be around $250 a wheel, plus the brake controller in the pickup. You'll need a complete brake assembly, plus a drum, bearings, races and seals. Should bolt on, check the Dexter web site, they can surely help.
Oldmax
06-27-2007 04:31:51
Be carefull if it has air brakes it requires a CDL to pull it or drive it . would change to Elect over Hyd .
oldrustycars
06-26-2007 14:50:49
It means the air brakes on his dump truck actuated the master cylinder on the trailer.
dboll
06-26-2007 09:22:12
must be a hydrovac like some grain trucks had
benny2
06-26-2007 09:11:22
 Costs about Re: Trailer Brakes in reply to BOBM25, 06-26-2007 08:57:50
You will need an elctro/hyd unit cost about $800 to $1200. Dexter axle has them.
