Tool Talk Discussion Forum
Remote Well Pump
cj3b_jeep
06-22-2007 06:39:18
I read something the other day about a remote well pump setup. I have an old dug well about 400' from any power source on my property and would like to pump water out of it. It's about 20 feet deep and has plenty of water. I was thinking about a deep cycle battery, a motor home pump and a solar cell. I could put the pump and the battery in a box. Any thoughts?
T_Bone
06-22-2007 15:14:30
 Re: Remote Well Pump in reply to cj3b_jeep, 06-22-2007 06:39:18
Hi CJ,
I boondock camp 100% of the time and get our water from lakes & streams using a Shurflo RV pump, 3.2gpm rated. The longest I've pumped is the pump at the lake using a lawn & garden battery then thru 200ft of 5/8" garden hose up a 75ft hill to my RV tanks. It took 20min to fill a 60gal tank so I didn't loose very much pumpimg action.
That is my typical hook up when I get water, my pump located at the water source with about 3ft of lift max. The pump is rated at 25ft of suction lift. I've been using this set-up for the past 20yrs. Flojet now builds a better RV water pump, about $95, 5gpm 25ft/sl rated.
These RV pumps are NOT designed for continious pumping and won't last long under those conditions, maybe 3mths. You can add a large pressure tank, 32gal drawdown, about $365, that will make the pump last a couple years.
A Unisolar US64 PV a unbreakable PV, about $325 delivered, works well for batter recharging with a MorningStar charge controller, about $55.
Any good 12v deep cycle battery will do, about $60 at WW or Autozone. The pump draws about 5a and the PV will keep up with the pump usage so a cheap battery will work well here.
T_Bone
buickanddeere
06-22-2007 11:44:05
Just run #10 conductors and run a 1/2 HP 240V pump. Put a power factor correction capacitor on the pump motor if you want to be extra certain. Less $$$ money and head aches in the long run.
Roger in Iowa
06-22-2007 08:59:21
Why not put in pipe, cylinder, pump and pump jack powered by a small gasoline engine. That is what I use. Don't need a reservoir as you can pump and irrigate at the same time. Costs a few bucks but excellent results.
Roger in Iowa
John T
06-22-2007 07:31:06
I seriouslyyyyy yy doubt those small 12 VDC RV or Marine diaphram type water pumps will lift water anywhere near 20 feet (I doubt even 20 INCHES), they are usually mounted where its gravity feed into their input!!!!! !!!!! Heck even a shallow well centrifugal jet pump cant lift much more then that.
John T
frankiee
06-22-2007 07:22:15
Would that be 20 feet up the well and then 400 feet to its destination or just up the 20 foot well?
CWL
06-22-2007 06:57:17
Would that pump have enough lift capacity to raise the water up 20'?
cj3b_jeep
06-22-2007 07:26:12
 Re: Remote Well Pump in reply to CWL, 06-22-2007 06:57:17
it would be 20 feet up the well and then either to a storage tank or to a hose for watering raspberries. Not sure if a 12 volt pump would lift water 20', but 20' seems to be the magic number for most small pumps.
Mattlt
06-22-2007 10:03:18
 Re: Remote Well Pump in reply to cj3b_jeep, 06-22-2007 07:26:12
It would be easy to test. Get yourself an RV pump, and set it up next to a water source (at ground level) Add 20+ feet of discharge hose, then raise the end of the discharge hose to the point where it stops flowing water. You might get wet, but it could be a fun experiment for the kids/grandkids.
In your situation, you may need to lower the pump down into the well. I personally doubt it would be able to lift the water up 20' with much efficiency. But, it might be able to push it that far.
The 20' magic number is on the suction side of the pump.
Mattlt
06-22-2007 08:30:39
