Tool Talk Discussion Forum
Converting a jet pump
OliLt
06-18-2007 18:58:10
Is it possible/practical to convert a 2 pipe, deep well jet pump to a simple irrigation pump? I want to avoid tanks, pressur switches, or special plumbing. Water would come from a lake and supply a garden hose with a traveling sprinkler.
buickanddeere
06-18-2007 19:40:08
 Re: Converting a jet pump in reply to OliLt, 06-18-2007 18:58:10
Move the ejector from down on the well and bolt it back onto the side of the pump.
T_Bone
06-18-2007 21:46:57
 Re: Converting a jet pump in reply to buickanddeere, 06-18-2007 19:40:08
And you'll need to add a in-line/swing check valve on the back of ejector.
Without automatic pump controls, you will quickly burn up pump seals and/or motor.
T_Bone
