Tool Talk Discussion Forum
XRogerX About Compressor
KCtractors
06-18-2007 18:21:27
third party image
Here are some pictures of the compressor from a earlier post!
KCTractors
06-19-2007 20:37:25
 Re: XRogerX About Compressor in reply to KCtractors, 06-18-2007 18:21:27
Thanks for all the help XRogerX.
KCTractors
06-18-2007 18:48:41
third party image
I'll try again!
KCTractors
06-18-2007 18:58:59
 Re: XRogerX About Compressor in reply to KCTractors, 06-18-2007 18:48:41
third party image
I have to work on the multiple pictures1
KCtractors
06-18-2007 18:25:32
There was supposed to be two pictures. Hope this helps you. Thanks
XRogerX
06-18-2007 20:06:58
 Re: XRogerX About Compressor in reply to KCtractors, 06-18-2007 18:25:32
Ok, the big tank at the back with the dipstick is your compressor oil reservoir. There should be a simple plug or valve on the bottom to drain it for oil changes. The other tank attached to it is the actual air/oil separator tank. On units this old, they were sometimes stuffed with wool or felt with alternating perforated metal plates to keep it all compacted and in shape. If that's the case, it may be easy, or hard to replace. Easy, if you can access a source of the separator material, or hard if you can't. You may need a press to reassemble the insides. If there is a steel and paper element inside, whatever you do, if you take it out, resist the urge to wipe off any oil that may be covering any numbers on it, since the numbers will usually come off with the oil, then it becomes more difficult to find a new one. At the end farthest from the oil tank, there is a copper scavenge line on the bottom of the separator tank. This will draw off any oil that has made it past the separator elements and deposit it back into the air end for re-use. If this plugs up, oil passing will be excessive.
The smaller vertical canister at the back of the air end is your compressor oil filter. This cleans any crud out of the oil before it is injected into the air end. It is probably held on by a through bolt with a washer on the hex end. The air cylinder in front of the intake is the control to close the inlet valve, and close and open the throttle. Should be easy to cross reference to any major brand of filter cartridge.
I am pretty sure it's a vane. You can find out for sure if you just pull the four bolts holding the inlet valve on and peek inside.
