Tool Talk Discussion Forum
Sealed or shielded bearings?
markiz41
06-18-2007 08:45:36
I need to rebuild an electric motor and was wondering if anyone had any experience with ball bearings. The old ones were shielded on one side and had grease fittings in the motor housing. I wonder if I should just replace them with new rubber sealed, permanently lubricated bearings but I worry about the life span of a rubber seal in a motor, even though it only going to be used indoors. Any advice?
Steve Crum
06-18-2007 09:32:22
 Re: Sealed or shielded bearings? in reply to markiz41, 06-18-2007 08:45:36
The company that rebuilds virtually all the electric motors in this area went to using sealed bearings in all motors less than 50 horse about 25 years ago. This includes cheese plant operations and at the mill I work at now. I haven't noticed much differance in the life span of the bearings and these are wet and dry dusty conditions.
DeanO
06-18-2007 09:17:40
Just remember to pull the zerks and plug the holes so nobody greases your new sealed bearings.
Makes a heck of a mess in the end bell and windings.
markiz41
06-18-2007 10:06:52
 Re: Sealed or shielded bearings? in reply to DeanO, 06-18-2007 09:17:40
Good point, Dean, thanks. And thanks, everyone for the advice. Any preference as far as brand name or will imported ones do? They are 6205 and 6206.
Butch(OH)
06-18-2007 11:56:02
 Re: Sealed or shielded bearings? in reply to markiz41, 06-18-2007 10:06:52
I like the SKFs myself. As others said the rubber sealed bearings are OK in a motor just take out the fittings. For SKF bearings add 2RS to the bearing numbers you have and that gets you a rubber seal on each side or 1RS gets you one. If youi decide to go with shields then add Z for one or ZZ for two.
Mike M
06-18-2007 10:28:04
you can get them dirt cheap from an outfit I think called skatebearings.com
fzbcheve
06-18-2007 08:56:28
Go with the rubber sealed bearings, and you will never have to worry about them again. If you have a hard starting problem, then go with the steel shielded bearings. They have less drag, and start easier.
