Oxy-acetylene cutting
Will
05-29-2001 07:09:40
I've got a nice piece of 1" steel that I want to cut that has been in a fire so it's a little rusty but I'm having some real problems with the thing. Are there any kind of guidelines for gas pressure and steel thickness in oxy-acetylene cutting? I've cranked up the gas a little because it didn't seem like the preheat was heating the metal enough and it is getting through the piece but it's very sloppy and there is a lot of pooling of metal on the top of the plate. Any suggestions? I really appreciate it.
wrenchman
06-02-2001 01:22:52
 Re: oxy-acetylene cutting in reply to Will, 05-29-2001 07:09:40
sounds like your tip is too small.i commonly cut 1"plate at 4to6psi acetylene and 25to30psi oxygen.if torch won't cut 1"plate clean try next size up tip.should be a # on the one you have.most welding supplys have a chart that will tell you what size tip you need.
this dude is just not cut
10-23-2003 12:00:57
 Re: Re: oxy-acetylene cutting in reply to wrenchman, 06-02-2001 01:22:52
your cutting is not write balance your arm and if that doesnt work your tip is too small if that is not your problem then get a new torch
S Bogusta
05-29-2001 12:46:18
Will I just cut some 1' plate i used a #2 tip w 25 psi oxygen and around 4 psi of acetylen, Use a straight edge, like angle iron clamped on to the work piece. Cutting speed is around 10 to 14 inches per minute. I can E mail you a chart if you wan't .
Will
05-29-2001 19:31:22
 Re: Re: oxy-acetylene cutting in reply to S Bogusta, 05-29-2001 12:46:18
I'm not really sure what kind of tip we used but the acetylene was at 4 and the oxygen was higher than 25. What kind of metal were you cutting? I'm guessing that this stuff that we cut was hardened steel since it was taken off some equipment.
Will
05-29-2001 16:44:16
A chart would be awesome. Thanks.
