Tool Talk Discussion Forum
Wire feed problem with H/F welder
Stan in Oly, WA
06-16-2007 20:37:04
One of my best friends is dying of cancer and gave me a lot of equipment which has had little or no use. Not a very happy way to end up owning something. One of the things he gave me was a Chicago Electric (Harbor Freight's brand) Dual MIG 151 welder. He set it up to run flux core wire, at least there's a roll of flux core in it and the polarity is correct. The machine has never been turned on.
Today I changed the plug to one I could use and tested the welder. I have to admit I'm even less impressed with the welder than I thought I'd be. There's no tensioner on the spool of wire, although what is there might work on a larger roll. As a separate issue, the wire feed is very uneven. The drive roller lets the wire slip and feed unevenly until the idler roller is tightened against the drive roller to the point where it stops the wire completely.
Does anyone have any advice for me about how to make this work? I own a Lincoln wire feed welder, plus I use Lincoln and Miller wire feed welders at school, and I'm responsible for making them work when students have troulble with them, so the problem isn't that I don't understand this type of welder. The problem for me is this brand and model.
Stan
Dan in Ore
06-19-2007 03:15:21
 Re: Wire feed problem with H/F welder in reply to Stan in Oly, WA, 06-16-2007 20:37:04
I own a HF 90 amp flux core wire welder and I just love that little machine. The only problem I have is the spatter, but am told that would be the case with any flux core welder. I do all but the heavier welding with it.
Stan in Oly, WA
06-19-2007 02:11:55
Thanks all. Good advice, as always.
Stan
T_Bone
06-18-2007 02:27:56
Hi Stan,
Sorry to hear about your friend.
The guys have already made some excellant suggestions. I would see what the wire spools like without being inside a liner? Then go from there.
My list would be:
1: liner problem
2: drive roll(s) problem (groove shape or worn) plastic gears?
3: Electrode wire problem
Then go from there if not resolved.
T_Bone
Steve Crum
06-17-2007 06:29:53
My recommendation would be to sell the H/F welder for what ever you can get out of it, and donate the money to the hospice program or other final caregivers for you friend, in you friend's name. Otherwise you in for a lot of aggravation. Stick with the Miller brand.
Little Ed
06-17-2007 05:28:17
The little H-F unit that I tried had a liner that was a piece of opaque plastic tubing, First time I tried thread wire throgh it, the wire punctured the tubing. Never did get it to settle down and run a good bead. If I remember right, the flux cored wire should be run on a serrated groove on the drive roller. It is a harder wire and slips in the smooth grooves. I can"t remember the polarity setting, but I think it is the opposite of running solid wire? I would think that some way to put a little drag on tha spool would be a must. Hope this helps.
Little Ed
06-17-2007 05:36:32
 Re: Wire feed problem with H/F welder in reply to Little Ed, 06-17-2007 05:28:17
Just went and looked on my Miller 130, and the fkux core should be run on reverse polarity and the solid on straight. Question for someone with a bigger machine. Do the larger machines work that way? I would have bet money that the solid wire was run on reverse polarity. but that could be why have not been able to retire yet.
Little Ed
06-17-2007 08:35:33
 Re: Wire feed problem with H/F welder in reply to Little Ed, 06-17-2007 05:36:32
Disregard previous post. Flux cored is straight polartity. solid is reverse polarity. Some days you couldn't pull my head out with any tractor.
Ryan - WI
06-17-2007 05:24:20
I would check the rollers. My guess is that they are either the wrong diameter or they are not compatable with flux core. If they are a V roller rather than a U they will often collapse the core in flux core and cause drive problems like you are experiencing.
~A fellow shop teacher
dan hill
06-17-2007 04:49:43
I use a Miller 135 mig and I cant see how a machine like this can be built cheap.The difference in price between Miller and HF welders should be fair warning.You could have the wrong liner or tip in the HF.Wire diameter could be off.Check with calipers.The Miller 135 weighs 65 pounds,some import welders weigh a lot less but claim higher output, wonder how they do it?
rad
06-18-2007 13:19:05
 Re: Wire feed problem with H/F welder in reply to dan hill, 06-17-2007 04:49:43
I know how they did it! I too bought one of these units. They rate it at a 10% duty cycle. Basically that means you have to wait 9 minutes for every minute you weld. And there is a thermal cutoff that pops off after about 30 seconds.
The HF units are junk unless you are welding very light material (tin) and not very much at a time. I bought a Miller 210 that will weld all day long.
