Tool Talk Discussion Forum
PW still bein ornery
JoeK(WI)
06-16-2007 19:25:02
Devilbiss 2400psi with 5.5 Honda Vert. Maybe two hours total run time since new,Ran fine last year,Drained,flushed,fuel stabilized and kept indoors over winter.Starts easily,but will not keep running unless under 1/3-1/2 choke.Tip,wand and hose clean and clear,pop-off valve cleaned and lubed,manually cycled several times,Sea Foam in gas,new plug.
Will run and spray though not full rpms with choke partway on,on trigger release governer madly "hunts" and eventually motor dies from load.With tip removed(or low pressure mode)unit will run with choke off and minor hunting,but will immediately lug out and die if switched to HP mode.
Carb appears spotless,bowl clean,linkage/springs correct(No adjusters on carb)Fresh clean gas.
-To me it seems like carb/fuel problem rather than loading one.Any known gripes w/Honda 5.5 or 6hp engines...never owned on before,kinda wish I didn't now :(
Vern-MI
06-18-2007 04:01:52
 Re: PW still bein ornery in reply to JoeK(WI), 06-16-2007 19:25:02
Is the throttle plate shaft stuck or sticky in it's bore?
Greg_Ky
06-17-2007 11:30:24
If it is hunting it has always been my experience that it is running lean pull the carb apart clean and reinstall. HTH
tinyy
06-17-2007 03:32:09
Could be fuel line colapsing or fuel filter pluged.
