Tool Talk Discussion Forum
Trailer brakes
Ted in NE OH
06-16-2007 08:17:11
I have a trailer with brakes on only one axel. Are the wires from the left brake wired in parallel or series with the brake on the right?
Oldmax
06-25-2007 05:54:00
 Re: Trailer brakes in reply to Ted in NE OH, 06-16-2007 08:17:11
They are wired in parallel Be sure you have a good ground I always run ground back to battery post might save you some trouble later on with lights & Brakes .
Oldmax
06-25-2007 05:53:01
They are wired in parallel Be sure you have a good ground I allways run ground back to battery post maght save you some trouble later on with lights & Brakes .
John T
06-16-2007 10:38:44
Yeppers, its all a paralell circuit where you apply voltage to alllll lll the brake magnets, regardless if 1 or 2 or 3 or 4 etc. Many problems are from POOR GROUNDS or those cheap crimp on wire connectors grrrrr rrr
John T
onefarmer
06-16-2007 08:30:10
parallel
