Removing Jar Labels
Phil in MS
05-29-2001 06:07:15
I have saved some plastic jars to store nuts, bolts, washers, nails, small parts etc. I plan on soaking these jars to remove the labels so the contents will be more visible. What should or could I put in the water that will allow the label to release easier or quicker?
Thanks
John in MA
05-31-2001 21:02:57
 Re: Removing Jar Labels in reply to Phil in MS, 05-29-2001 06:07:15
Use hot, soapy water for water-based label glue. Use kerosene to take off glue that water won't. Kero is safe, cheap, nontoxic, doesn't stink too bad,
Bud
05-30-2001 19:02:52
This is kinda off topic but it's a neat idea that I saw on the net somewhere. I save one-quart motor oil containers and clean them good with thinner. Then I cut off the necks at a diagonal big enough to get my fingers inside. I turn them on edge (on their sides) and stack them together side by side on a metal shelf and store screws and other hardware. I can just browse the open ends and pull out the container that I am looking for. Each container will hold mucho nuts and bolts etc. I have them color coded also. Looks nice and is handy too. Hope the idea helps.
Tools
05-29-2001 20:45:36
I've done hundreds of beer bottles by soaking them in ammonia and water for a day or so. Most of them are just laying in the bottom of the bucket and don't even require scrubbing.
Tools
PS I did this so I could reuse the bottles for homebrew, just in case you were wondering!
D W
05-31-2001 08:40:58
 Re: Re: Removing Jar Labels in reply to Tools, 05-29-2001 20:45:36
I find pipeline detergent, to be the most usefull product, for cleaning up brew equipment and carboys. It will also remove labels. It is available at most Farm&Fleet or TSC stores in the Ag or dairy section. HBA member.
Paul
05-30-2001 13:00:48
Looks like you'd post your favorite recipe for us.
scott
05-29-2001 20:11:33
Try soaking the label with wd40, wait a few min. it will slide off. No damage to plastic.
krum
05-29-2001 07:20:54
Try using a blow dryer or a heat gun to warm the label. after you remove the label apply some goo-gone to remove any residue. I remove hundreds of labels this way on my job.
M.R.
05-29-2001 06:29:35
Might try filling a couple with hot water and letting them set a few minutes before peeling the label off. Be careful not to get the labels wet and most of the glue will come off with the label.
Brian G. NY
05-29-2001 06:47:57
 Re: Re: Removing Jar Labels in reply to M.R., 05-29-2001 06:29:35
I do the same as M.R. does. It works in most cases, however, if some of the adhesive stays on, I remove it with my wife's "Goo-Gone". It is a pretty good solvent for this kind of work as it is not "strong" enuf to soften the plastic. I find that the "permanent" markers work good for labeling these plastic containers.
