Tool Talk Discussion Forum
Caulking remover
Bret4207
06-11-2007 13:41:54
Any recommendations on an effective remover for caulking in a shower? I used clear caulk when I put it in. Now it's yellowed out and I want to re apply the caulk. I need a good remover. Fiberglass shower surround, off white. Thanks
dds-inc
06-11-2007 21:13:46
 Re: Caulking remover in reply to Bret4207, 06-11-2007 13:41:54
razor blade in a pair of vise grips.
About the easiest.
Vern-MI
06-11-2007 17:58:39
McKanica� Silicone Caulk Remover Gel (0354)
Price: $10.49 Item no: 1241017
Ace Hardware
Breaks down 100% silicone caulk for easy removal Ideal for removing caulking around tubs, showers, ceramic tiles, fiberglass, and most plastics Also removes industrial silicone fillers and adhesives Designed for 100% silicone, but may soften non-silicone caulks, adhesives, fillers, plastics, and rubbers Clean up with soap and water Low odor, no residue 3 Oz. Squeeze Tube
Gary from Muleshoe
06-11-2007 15:26:00
Get yourself a good razor blade type scraper and go to town. This is the best way I know of. The surface is all that would yellow so you do not need to get all of out of the cracks unless you are using a different type of caulking. But it is a personal preference how much you take out.
