Tool Talk Discussion Forum
Grease Gun Couplers
MN Scott
06-11-2007 06:03:11
What brand of grease gun couplers do you use? I seem to have no luck finding ones that last anymore. Seems that they last for maybe two tubes of grease at best then they start leaking more grease than gets into the fitting. When I was young one would last a year or two. I have tried about every brand I can find from the cheapo's to the high priced ones with similar results.
TGIN
06-12-2007 02:13:41
 Re: Grease Gun Couplers in reply to MN Scott, 06-11-2007 06:03:11
My tip had been on the gun since new , I`m guessin 10 yrs maybe more . It started to leak a little so I thought I`d replace it . The new one did`nt last one tube and could`nt get it ON the zerk , I put the old one back on .
dds-inc
06-11-2007 21:17:22
THey say you can break a rusted tractor engine loose by pumping grease into a zerk adapted to a spark plug hole.
I find this very marginal to achieve considering that each grease fitting and gun behave differently from all the rest, some too tight, some too floppy, too messy, too leaky, and whatnot.
Rodman
06-11-2007 19:58:51
Worn fittings? How come the Tiawanese couplers worked so well on those same fittings? And I even did try some new fittings in place of those that leaked so much grease out, but the result was the same with either fitting. I will try to find some Plews and see if I have better results. Next time I am a Habor Freight I will see if they have couplers and try some of them out just to see. Thanks for all who kicked in to this question!!!!!
IHC Red
06-11-2007 18:58:39
I've been frustrated too... but I've had the opposite problem. I get them on the zerk and I have to pry them off with a big screw driver.
This happened with Lincoln and with a cheaper brand. The tension on the grips is WAY too much. I've loosened the outer tip of the coupler but of course it doesn't stay in adjustment very long.
What the heck is going on with these new couplers anyway ? I have an older one I got about 10 years ago and that one has always worked perfect.
MN Scott
06-11-2007 19:42:02
 Re: Grease Gun Couplers in reply to IHC Red, 06-11-2007 18:58:39
I have had them to tight to remove to. When that happens your usally in a hurry and go from side to side then give it a good yank thus breaking the zerk or ruining the coupler. I have solid pipes on my lever guns so I can put quite a bit of pressure on them but nowere's near the 10000 psi the gun is capable of. My zerks are not worn on my new baler so thats not a problem. I guess its a problem there is no easy answer to, maybe buy up some old grease guns at auctions to find an old quality built coupler that still works.
fzbcheve
06-11-2007 18:34:44
Maybe the zerk fitings are worn. It does happen.
Jon hagen
06-11-2007 15:26:36
Got one on my $49.95 Harbor Freight 12V grease gun that has pumped over 60 tubes of grease, but finall got loose after trying to force grease into a plugged fitting and did not have brains enough to give up and clean the fitting. I took the tip apart and was amazed to find it had 4 hardned jaws. The jaws were OK, but the extreem overpressure had puckered the end of the housing kind of like grandpa about to launch a stream of tobacco juice. I set the housing on the anvil and hammer tapped the end of the tip back flat. Works like new again. Not sure if you can buy the tips seperatly in the HF catilog, but would be suprised if you couldnt.
oldrustycars
06-11-2007 15:05:42
I use Lincoln, with good sucess. I always keep one hand on the coupler to hold it on the fitting, and one on the gun. Since I dont like the pistol grip guns, I had my local hose shop make me an extra long grease hose so I can lay the gun down on the floor, or the machine while pumping the lever. Works great.
jmixigo
06-11-2007 14:44:39
I have three made by Plews that I've been happy with. I bought 3 whips and a card of 10 ends at the local hardware store off the junk table. Pretty good stuff.
Rodman
06-11-2007 09:14:36
Lincoln was what I just bought and in my opinion they were junk, and I expected much better from them. I've got four new ones that I thought about taking out and planting them to see if they would grow because they sure are not worth keeping in my shop.
Rodman
06-11-2007 09:11:19
I can't help, but I sure would like to know because the last expensive ones I bought were not even as good as the Tiawanese ones that I was replacing. This is a great question someone jump in and give us the information that we need?????
markiz41
06-11-2007 07:05:04
Lincoln.. Been the industry standard for a while.
Of course, since they moved some of their production overseas, the quality suffered.
