Tool Talk Discussion Forum
WELDER SET UP
Skybow
06-10-2007 08:09:56
I think I have located a nice used Dialarc 250. It doesn't have power cord or leads and my garage doesn't have 220. What size/type wire do I run from my panel to the receptical? What size power cord? Are 25-30 foot long #2 leads heavy enough for normal stick welding? If I get the welder I plan to start the Welding certificate program at the local CC. As of now I'm just wanting to fix a few broken things around the farm. Thanks
135 Fan
06-11-2007 22:24:25
 Re: WELDER SET UP in reply to Skybow, 06-10-2007 08:09:56
A dial-arc 250 would need at least a 60 amp breaker. Does it have power factor capacitors? It is similar to a Lincoln Ideal-arc 250. A good machine but not as good as the Lincoln in my opinion. Dave
SKYBOW
06-10-2007 22:33:56
Thanks guys. This is exactly the info I needed.
Skybow
Stan in Oly, WA
06-10-2007 11:55:06
Hi skybow,
The technical information John T. provided is completely accurate but he didn't address the issue of the size of leads you will need. One of the many amperage carrying capacity charts available online shows that #2 wire can carry 200 amps 50 feet. Don't forget that this is a circuit so 50 feet means electrode and ground cables of 25' each.
The leads from typical 225 amp AC or AC/DC welders are usually smaller than #2. Lincoln and Hobart, to mention 2 that I have checked recently, use #5 AWG leads. Remember that the duty cycles of these small welders will not allow you to use higher amperages for very long, and that the leads are only about 12 to 15 feet long. #2 leads would be great---if you can get a second mortgage to buy them.
All the best, Stan
Bob seND
06-10-2007 10:45:30
Skybow,
Log on to the millerwelds site. Download the Dialarc owner's manual. The manual gives the setup
procedures, wiring requirements etc. You have to put in your serial number (or a dummy one like jd102503). The Dialarc is a great stickwelder!
Bob seND
http://millerwelds.com/service/ownersmanuals.php
John T
06-10-2007 08:58:18
Sky, of course the higher amperages youre welding with the bigger wire you need and duty cycle comes into play etc etc etc. Look for a nameplate rating on the welder as far as its exact requirements:
That being said, many typical 225 or so amp Buzz Box AC stick welders require a 240 volt 50 amp branch circuit feeder and the power cord plug (and matching receptacle) is a 250 volt 50 amp 2 pole 3 wire grounding type consisting of two hot phase conductors plus an equipment safety ground.
Such a branch circuit from your panelboard (but still dependant upon length) could consist of 6-2 with ground feed wire (Red and Black Hots plus a bare or Green equipment ground) served by a 240 volt 2 pole 50 amp panelboard circuit breaker. Then match the receptacle to the welders AC Power cord plug which may ????? well be, as mentioned above, a 2 pole 3 wire grounding 250 volt 50 amp.
That regular welding lead cable consists of fine strand wire which gives it increased flexibility.
John T
