Tool Talk Discussion Forum
Hydro test
MF294-4
06-09-2007 19:26:12
What can I use for a pump to hydro test a aircompressor tank?
WaltMo
06-09-2007 21:47:34
 Re: Hydro test in reply to MF294-4, 06-09-2007 19:26:12
To hydro test a pressure vessel you have to submerge it in a water tank, read the water level, pressureize the vessel read the water level again. The rise in water level will tell how much the tank is expanding.
You need to know the specs. for each tank.
hth WaltMo
Wardner
06-09-2007 19:43:00
Use a grease gun. Check my post several threads down.
TimV
06-09-2007 19:36:18
How high of pressure are you going to use to test it? If you're just going up to the max pressure you plan on using, just use another compressor. I usually just fill it 99% full of water and add air--the idea is to get it up to pressure without creating a big "bang" if it fails. If, however, you're trying to test it above your normal working pressure, then you're going to have to scrounge up a higher-pressure compressor--perhaps one used to fill Scott Air packs Got a friendly fire department handy?
Rod (NH)
06-09-2007 20:36:26
 Re: Hydro test in reply to TimV, 06-09-2007 19:36:18
For a proper hydostatic test you should go to 50% over the relief valve setting. If the tank won't withstand that, it is not safe (by definition) to operate with that relief valve setting. If you only test it to the "pressure you plan on using" you have no safety margin at all. In fact, you haven't even tested it to the pressure that could be obtained if the presure switch stuck. Either do it right or junk the tank. The risks are too great to do otherwise. See here.
Chris Jones
06-10-2007 15:48:38
 Re: Hydro test in reply to Rod (NH), 06-09-2007 20:36:26
I've had the pressue switch stick on me before. It pumped up till the relief valve opened and kept pumping. I unplugged it. Sometimes it would work and sometimes it wouldn't and since it does leak down some it might turn on at any time of the day or night--me here or not. I couldn't trust it so I replaced the switch. I also installed a light switch before it's receptacle to turn of the power to it more conveniently. Now I turn it off whenever I'm not using it in case the new switch ever decides to start sticking.
Wardner
06-09-2007 20:53:49
Rod,
Did (or do you) you work for Process Engineering (now Chart Industies) in Plaistow, NH?
Rod (NH)
06-09-2007 21:05:58
 Re: Hydro test in reply to Wardner, 06-09-2007 20:53:49
Nope. I never even heard of 'em.
