Tool Talk Discussion Forum
annealing high (medium ?) carbon steel
Tim B from MA
06-08-2007 12:59:45
I am wanting to drill a few holes in bed frame angle iron. In the past it has played havoc on my drills as the hardness in the material is patchy, but mostly pretty hard for steel drills.
From previous discussions on this board, I am thinking that this steel has a higher carbon content.
Does heat and slow cooling anneal (soften up) carbon steel? I am thinking that before I drill, I will heat the spots I want to drill to cherry red and let it air cool.
Alternatively, where does one find carbide drills for steel? I don't think I've ever seen them at Home Cheapo or Lowedown.
Thanks.
Joe(TX)
06-09-2007 16:22:17
 Re: annealing high (medium ?) carbon steel in reply to Tim B from MA, 06-08-2007 12:59:45
After reading the replys to the posts you are most likley confused. The answer is:
If it is high carbon steel, heat the spot cherry read and let it air cool. Alloy steel reacts differantly.
Cobalt drills should drill better. You may be running the drills too fast. As far as the strength, the bed frames are stronger than normal angle. A little more prone to cracking though.
Tim B from MA
06-10-2007 10:56:42
 Re: annealing high (medium ?) carbon steel in reply to Joe(TX), 06-09-2007 16:22:17
I'll give heating and air cool a try - the more involved annealing that others have mentioned (burying hot piece in wood ash etc.) sounds neat and something that might come in handy some day, but too involved for this project.
Regards
Tim
NEsota
06-09-2007 12:48:40
Great discussion. U guys answered a bunch of questions I had.
Chuck MA
06-09-2007 08:42:13
Tim try a cobalt drill. They have worked for me, Using a drill press really helps also.
Chuck
dan hill
06-09-2007 05:06:34
Bed frame steel is high carbon and not good for much.My welding table,tool stands,tractor carry all, cultivator,Lift boom and log hauler are made from new steel.Scrap steel takes time to collect and your projects look like scrap when finished.
Tim B From MA
06-09-2007 07:08:34
 Re: annealing high (medium ?) carbon steel in reply to dan hill, 06-09-2007 05:06:34
I wouldn't use it for anything my life depended on, but I think it is great stuff for the price.
I've never used it for anything that I cared much about the looks, but my brother made a beautiful welding cart for his little mig out of it, and with some automotive paint left over from a truck he had, the cart looks like he paid more for it than for the welder.
Right now I am making up the back half of a set of ladder racks for my pick-up that will get used about once a year (for a canoe for work, usually). If I were going to spend the money to by new steel for such a project, I'd be better off just buying a set of ladder racks.
I've never had any trouble welding it, just drilling it. It is doing wonders for my drill sharpening skills though :)
mjbrown
06-09-2007 03:44:12
I don't think annealing is the right way to do that particular job, but to anneal the steel should be taken above 1330 deg.F (non magnetic state) then cooled in carbon rich ashes or cinders and slow cooled for at least twenty minutes..
flying belgian
06-10-2007 20:09:14
 Re: annealing high (medium ?) carbon steel in reply to mjbrown, 06-09-2007 03:44:12
After all that and you only end up with a 6 ft. piece of angle iron. Go to a steel warehouse and buy a new length. You can then cut and drill any way you want.
benny2
06-08-2007 22:20:53
 Heat then Re: annealing high (medium ?) carbon ste in reply to Tim B from MA, 06-08-2007 12:59:45
Heat your area then bury in wood ashes, this process will anneal any metal including tool steel and car springs. If well buried it can take a day to cool. So dont go in the ash pile for the metal with your bare hand. Air cooling will never do it!
Kevin (FL)
06-08-2007 21:52:53
Tap Magic is the best I've ever used for drilling or tapping. Learned about it in the shipyard 30 years ago and been using it ever since. Always center punch where you plan to drill and if you have trouble drilling whatever size bit you're using, try drilling an 1/8" pilot hole first. Usually I only do that for thicker material but if you're having trouble with that material try it too. I wouldn't bother trying to anneal a bed frame--it's nowhere near tool steel properties--not really "heat treatable"....
Tom Whitehead
06-08-2007 21:39:58
well Tim, that old bedframe stuff is really crappy. You can get some really hard spots in it, and sometimes it will just crack in two if you"ve done anything to it like Weld it. I guess it is a really high carbon steel but it"s also probably pretty high nitrogen which does the same thing as carbon except that it makes it brittle as heck. I haven"t had any good success using carbide drills for anything except concrete. They cut pretty well at first, but then just as you"re breaking through they seem to grab and shatter. So, when I"m doing stuff like that, I just go really slow, put a lot of pressure on, and just count on a resharpening my bits. use cutting oil if you have it, automatic transmission fluid if you don"t.if you know how to sharpen them freehand that"s good, if you don"t, then you should learn. Or one of those drill doctor"s would make a very good investment.
good luck, Tom
dds-inc
06-08-2007 21:19:34
If you DO get a titanium drill bit, which is harder, beware of letting the drill twist your arm around. But enjoy a nice cut if you use oil as well.
rockyhawaii
06-08-2007 20:52:48
I've drilled quite a bit of bed-frame iron, and find that a drill press really makes it a lot less labor-intensive. I use regular steel bits and keep the Drill-Doctor handy.
Davis In SC
06-08-2007 14:27:54
Heating and cooling should work, but letting it air cool, it might harden back. What I have done is: Heat til red, then play the flame on the spot so it cools slower. Propane torch works good for the last part.
glennster
06-08-2007 14:26:52
i drilled out some mower blades to a larger bolt hole, used a cobalt bit from napa. lots of cutting oil, slow speed, cut real good.
TimV
06-08-2007 14:19:13
A good tool catalog or somewhere like McMaster-Carr should have them. However, if you're just doing a couple of holes that don't have to be a perfect diameter, you can use carbide-tipped masonry bits. Just did this the other day to a set of lawnmower blades that needed the center hole reamed from 3/8" to 1/2". Every 1/2" bit I had just bounced, but the carbide masonry bit drilled them.
