Tool Talk Discussion Forum
does fertilizer go bad?
Chris Jones
06-08-2007 10:30:37
I"ve got some 10-10-10 that"s been sitting around the place for maybe 3 years. It"s a bit wet from absorbing moisture. Spreading it isn"t a problem but does it still posses it"s nutrients?
Chris Jones
06-09-2007 13:14:42
 Re: does fertilizer go bad? in reply to Chris Jones, 06-08-2007 10:30:37
Thanks everyone. I did put some out about 2 weeks ago. The grass looked kinda brown and wasn"t growning. I really can"t tell where it"s helped. Maybe it"s the hot dry weather. I have been watering the grass so that shouldn"t be it but.... Anyway, I going to wait another week or two and then get some more fertilizer.
dds-inc
06-08-2007 21:21:48
10 bags of triple 10 after 2 years found once again in the back of the shed = hardness of cement blocks
john in la
06-09-2007 07:17:21
 Re: does fertilizer go bad? in reply to dds-inc, 06-08-2007 21:21:48
Try mixing it with water to let it dissolve; and then pour the water on your plants.
kopeck
06-08-2007 14:27:17
Nope.
Might get real hard though. We had some stuff that sat around for years (10 plus) and was like a brick. We gave it to a friend that happened to also run the local fertilizer plant, he just ran it though their processor and it was good as new.
Use it if you can.
K
jdemaris
06-08-2007 12:46:51
Interesting question. I had a bunch of triple 15 laying around, maybe 5 years old. Much of it was liquifying and the bags were falling apart. I spread it on my hay fields - lightly, and it - in some areas - it killed the grass and turned it yellow. That's was kind of unusual. All the grass was knocked back a bit for a year, wasn't even quite right the second. I've spilled fertilizer for years, when crossing fields with a corn-planter - and usually the grass grows like crazy where the fertilizer drops.
My case isn't exactly scientific, but it certainly did a number on some of my hay field.
bo
06-08-2007 12:33:07
What's the difference? You have to get rid of it anyhow. Spread it and watch for greening up. If it's no good, you won't hurt anything.
bo
06-08-2007 12:32:41
JMS/MN
06-08-2007 12:12:54
If it got wet, I wonder if some of the N would have gassed off, but I would expect it to be close to original value.
