Tool Talk Discussion Forum
Trailer metal question
jmixigo
06-08-2007 03:22:17
I'm building a trailer to haul my tractor on. The main frame rails are 4 inch square tube with 1/4 inch walls. Materiel was dictated by what was in the scrap pile at work. I want to add a dove tail 2 feet long but I'm out of 4 inch tube except for a piece of 4 inch square 1/4 inch wall in 316 stainless. Two questions- 1 - Will the joint be strong enough? I think so but have little experience with joining dissimilar metals. My buddy who will be makeing this joint is certified on pipe and crane structure. This piece won't be stressed except when loading or unloading. And 2- will 316 take paint OK?
We know how to make the weld and have every thing to do it with, but some of my co workers have gotten me doubting myself.
Kevin (FL)
06-08-2007 22:12:44
 Re: Trailer metal question in reply to jmixigo, 06-08-2007 03:22:17
No problem to join the 316 SS and mild steel. I think we use a 309-16 rod--Lincoln sells an all-position rod for this application but I don't know the exact part #. Don't know if you're stick welding or wire welding, but look for that alloy filler material and you'll be fine. If your welder is certified, he'll know the regular stuff like joint prep and proper root gap, etc. To eliminate the stress on the joint while loading, why not fabricate the ramps to take the weight while loading? But to conclude--I agree with Steve about not using such fine material for a trailer frame, but if you must....sand blast the material and use 2 part epoxy paint--like an Ameron 385 or equal, Sherwin Williams and International Paint and others--they all make what's called in the industry "surface tolerant epoxy"--its great for unblasted or sand swept mild steel too. It covers light rust and mill scale and dries rock hard. Its not good for a glossy or fancy paint job though--just good for preservation.
jmixigo
06-09-2007 03:29:59
 Re: Trailer metal question in reply to Kevin (FL), 06-08-2007 22:12:44
Thank you. I work in a shop where we do Industrial piping, metal fab, and contract maintainance work. I'm a mill wright and a noncertified "functional" welder. I was only concerned because joining mild steel and stainless is some thing we just don't do. To complete the trailer I needed two pieces of tubing about 2 foot long and these were available. All stressed welds were 6010 root welds with 7018 caps. Non stressed were MIG welded. This joint was done with 308-16 if I remember right, it was pretty late last night when we finished.
Ken Crisman
06-08-2007 05:59:29
Hi , for hauling a tractor , use nothing shy of 6" tubing or channel for the frame . What you're wanting to use will get you into a nasty situation you don't want someday, somewhere along the road . Another thing if you get checked out by the cops with the tractor on you may face a real unwanted expense . Your 4" may be ok for a small utility trailer or landscaping trailer but nothing more . Please for yours & others safety , don't do it with 4" .I know a guy who made a trailer like you're wanting to do & I saw him sitting along the road with a load of gravel & the trailer was buckled in the middle from lack of strenghth .He was warned ahead of time also but wouldn't listen to advice . Good luck & God bless, Ken
jmixigo
06-08-2007 13:25:52
 Re: Trailer metal question in reply to Ken Crisman, 06-08-2007 05:59:29
It is quarter inch wall thickness 4X4 tubing not thin wall stuff. From the suspension forward it is under pinned with quarter inch web six inch channel, and from there back it is under pinned with 4 inch "I" beam. This trailer will weigh over 4000 pounds and has 3 6000 pound axles with brakes under it. Flimsy it ain"t.
Steve Crum
06-08-2007 04:09:53
316 stainless is very expensive metal even in scrap form to be using on a trailer. I would avoid using it on a trailer frame even though you could likely get a strong enough joint. Road shocks and vibrations could lead to eventual cracking and breakage, stainless is fickle like that. Check with a new metal supplier as you can probably buy a new 20' section of 4" square steel tube for under a hundred. Save the stainless tube to build a spiffy new bumper
