Tool Talk Discussion Forum
distributor pulled
ed1964
06-07-2007 19:31:07
i got a ford 800 tractor and distributor was out..any ideas putting it back in correct position? thanks ,ed
old
06-07-2007 19:43:54
 Re: distributor pulled in reply to ed1964, 06-07-2007 19:31:07
Correct or working? If you want to get it working get #1 to TDC on the compression stroke then drop the distubutor in. Then line up the closes point in the cap and wire it up as the fireing order needs to be. If your worred about being 100% correct then you will also need to know which point on the cap it the one that #1 should be on.
