Tool Talk Discussion Forum
Idler hubs on trailer -- what mean?
rossow (mn)
06-06-2007 08:12:14
What are "idler hubs" and "idler axles"?
john in la
06-09-2007 07:14:51
 Re: Idler hubs on trailer -- what mean? in reply to rossow (mn), 06-06-2007 08:12:14
Bob has it right. A idler hub has no brakes. Prices are often quoted on axles with idler hubs then you add X dollars to add your extras. This is done because you can often put several differant kinds of add on's on the same axle such as elect brakes; hyd brakes; air brakes (larger axles); free backing brakes; ect.
old
06-06-2007 15:31:51
Heres some thing else they could be. An axle that only comes into play when the trailor is laoded to a point where the extra axle is need for the load. I have though about setting up one like that so when unloaded it runs on one axle then if loaded to a a little more a 2nd axle comes into play and then when loaded heavy a 3rd axle comes into play
oldrustycars
06-06-2007 13:46:19
Definately axles with no brakes.
Grub
06-06-2007 10:02:53
I agree with Bob- no brakes.
Bob
06-06-2007 08:38:02
Perhaps hubs and axles NOT set up for brakes???
JoeK(WI)
06-06-2007 12:18:57
 Re: Idler hubs on trailer -- what mean? in reply to Bob, 06-06-2007 08:38:02
Could it be referring to those "torsion"axles etc,which work like a spring loaded idler,rather than having conventional leaf or coil springs?
Just a thought-
Bob
06-06-2007 21:34:08
 Re: Idler hubs on trailer -- what mean? in reply to JoeK(WI), 06-06-2007 12:18:57
Take a quick look at the replacement axles available on the trailer parts site linked below.
The axles with out brake drums, or flanges for the brake backing plates to attach to are CLEARLY listed as "idler axles".
