Tool Talk Discussion Forum
Tachometers...Quality?
Glenn FitzGeral
06-05-2007 10:15:49
I'm looking at tachometers. The local auto parts stores list them for anywhere from $25.00 to $155.00. Generally the smaller the face, the lower the price, but is there much difference in quality? I don't need top-of-the-line, but I want something that's reasonably accurate and will last a while.
Thanks,
Glenn F.
Cliff (VA)
06-06-2007 05:04:00
 Re: Tachometers...Quality? in reply to Glenn FitzGerald, 06-05-2007 10:15:49
I used to work for a company that made tachometers here in Virgina. As a matter of fact I have been involved in the design of several.
Other than the large racing tachometers (which have features that I doubt you would ever use), all of our tachs were basically the same circuitry. The larger face, meant larger pointer, meant larger crosscoil (type of motor) to push it around. Some of our bigger units had stepper motors in them.
I would suggest that you find one that is big enought to read (the 52mm ones are too small for anything larger than 90 degrees of movement) and small enough to fit where you want to mount it. You may want to attempt to "match" the other instruments in you vehicle.
One other thing, you need to get a tach that is set up to get signals from the engine that is in your vehicle. Gas and Desiel use different pick up methods. Spend some time looking at this before you buy. Most tachs expect to pick up their signal at the points (or a tach output for electronic ignition) on a gas engine.
Email me if you have futher questions. I would be happy to help.
Cliff (VA)
oldrustycars
06-05-2007 14:56:23
try looking at www.jegs.com I like Autometer brand, still made in America.
Bob
06-05-2007 21:18:38
 Re: Tachometers...Quality? in reply to oldrustycars, 06-05-2007 14:56:23
Lots of USA stuff @ ISSPRO.com, too.
Glenn F.
06-05-2007 14:11:36
Tach is for my pickup truck.
