Tool Talk Discussion Forum
air compresser question
John300
06-04-2007 05:27:37
i have a Craftsman 5.5hp/25 gal vertical 110 compressor now, am looking to upgrade to a 60 gallon tank/220v belt drive compresser because I want something quieter in the shop than that screaming craftsman. Most 60gal tanks come with 3hp motors. What should I be looking for in a new one, why the hp difference? What are some suggestions when looking at new ones?
jeffcat
06-05-2007 10:52:14
 Re: air compresser question in reply to John300, 06-04-2007 05:27:37
Almost every one here has said the same thing. Fake stuff screems and good machines go putt..putt..putt..putt when they run. Slow speed pumps stay cooler and don"t pound themselves to death. I Love my Emglo pumps and they are pumpin fools! Look around and see if you can find one. The old Champions, IR, Kellog, and so on. Three phase is a great thing if you can get a hook up. Good old 220vac should serve you very well. My Larger Emglo is hooked up to 220 and the motor runs VERY cool and spins up instantly! Jeffcat
souNdguy
06-05-2007 07:16:11
I'd look for a 'real' 5hp motor on a 60g tank.. 220 of course.
Soundguy
Bernoulli/OR
06-04-2007 18:33:07
You will need a 220VAC motor with a belt drive to the compressor. The bigger, the better. Get more CFM than you need because the manufacturer's lie about that too. 12.3 Amps at 110VAC (6.1 at 220) is close to 1Hp. 1.5 (real)Hp is the practical max for any electric motor on a 110 20 amp circuit.
Wardner
06-04-2007 16:08:28
Don't all consumer type air compressors scream?
Don't all consumer type air compressors have a catastrofic failure within 500 hours?
The solution to air compressor bliss is to buy an old line cast iron pump mounted on a large horizontal tank.
Set it up in an outbuilding with a buried discharge line. The line will act like a condenser and a trap will remove the water. Don't make the line too large. You need enough velocity to clear the water. Compressing clean outside inlet air will also assure that the valves will not need much, if any, maintainance.
My Type 30 IR compressor (15 hp industrial) is seventy feet away from my shop. I can't hear it. It is in a concrete compressor room near my service entrance in the cellar. It has a magnetic starter, and when I need air, I just flip a toggle switch in my shop. I bought it used thirty years ago and it still runs fine. All I have done is change the oil a couple of times and drain the air receiver several times a year.
I think it is also relevent to mention that the pressure switch is set to 70# on and 90# off. That should add years to life of any compressor.
john cub owner
06-04-2007 10:37:42
I am assuming your Craftsman compressor is marked 5HP peak. If so it was a misleading marketing tactic that was performed by many manufacturers A few years ago that resulted in some class action suites. In reality it would be a 2 to 2 1/2 hp compressor. Companies are allowed to market motors with horsepower ratings based on current consumption, and those were marketed on the startup current consumption, not the running current.
Kendall
06-04-2007 10:05:47
What Rusty said. Go by CFM, not HP. 5.5 HP at 120V would be around 36 amps!!! You're on the right track with 220V and belt drive.
John300
06-04-2007 08:55:41
My current one is 6.4/scfm@90 psi it is a oiless direct drive
The one I am looking at is 11.3/scfm and is belt drive.
Yes I know they all make moise, but some make more than others.
Charles (in GA)
06-04-2007 06:41:15
I think the compressor John has now must be a oilless compressor. These are so noisy that you really should wear hearing protection, ear plugs, etc, when around them.
A belt driven, oil filled compressor will be much quiter.
However, CFMs are the way to shop and compare compressors. Most large compressors are given actual running hp ratings, while the cheaper consumer compressors, generally 60 gal and down, are given the bogus, starting hp ratings.
Charles
RustyFarmall
06-04-2007 05:45:15
Those horsepower ratings are mostly fictional marketing techniques. There is no way that a motor running on 110v will put out 5.5 HP efficiently. Likewise, the compressor you are looking at probably does not put out 3 HP. The actual horsepower of both those motors is probably closer to just one HP. The one basic item to consider when shopping for a compressor is the capacity of that compressor, given in CFM, cubic feet of air per minute. Also, ALL compressors make noise. You can either build an enclosure that will muffle the noise, locate the compressor in a seperate room, or just live with the noise.
