Tool Talk Discussion Forum
Windshield Removal tool
Slowpoke
06-03-2007 21:43:52
What manual tool can I use at the wrecking yard to remove an '80s Ford truck windshield? It looks like the sealant between the glass and the frame is black silicone as it's kind of rubbery. Thanks
rustyj14
06-04-2007 19:18:52
 Re: Windshield Removal tool in reply to Slowpoke, 06-03-2007 21:43:52
the guy who took out the rear window from whatever, didn't tell the whole story! Back/ rear glass is tempered, windshield glass is NOT! Ws glass will crack far easier than tempered glass. Windshield glass will crack--tempered glass breaks into tiny square pieces suddenly (Where did it go?)Awww, RATS!
1936
06-04-2007 17:24:21
Best to have some else take it out. You stand a 99% chance of breaking the glass as a rookie.
dan combs
06-04-2007 18:01:18
 Re: Windshield Removal tool in reply to 1936, 06-04-2007 17:24:21
put it in the sun {warm itup a little} get some baleing wire, from the outside ,slip threw top, and have someone inside and work all the way around, not to much pressure on the glass... when you go all the way around , then push gently on gleass,, work it slooooo oow.
Billy NY
06-04-2007 16:46:47
Look under automotive products, I used to buy a lot of architectural materials from this company and some glazing tools for the high end metal window and curtainwall business, they have quite a catalog.
Semper Fi Guy
06-04-2007 12:30:14
Hey Slowpoke,
I took a back glass out of a Caravan at the yard, the owner said if you break it , you still pay for it, But he watched me and I got it out with 2 Big Lots Store purchased putty knives that I paid less than $2 each for, I ground a notch in each one a little different and sharpened them like you would a knife...one had a claw like hook , the other was rounded in profile, I did not bend them , just changed the profiles, it cut the sealant fine working inside and outside the vehicle as needed, I even did this in the rain... the window felt nice and loose when the time came and it was not aware of being flexed at all, I got some new $12 a tube urethane sealant and a caulking gun and saved a bundle on my job....I wish you good luck, Semper Fi Guy
Slowpoke
06-08-2007 00:12:12
 Re: Windshield Removal tool in reply to Semper Fi Guy, 06-04-2007 12:30:14
Is your modified putty knife similar to a hook blade that is used in a utility knife? I think I'll try one and grind the rounded tip to a sharp point. On the other hand, the handle may be too bulky and get in the way with only 3/4" of blade exposed. Maybe just the blade fastened to a thin wood or plastic handle would work.
Slowpoke
06-05-2007 01:42:21
Some yards here are help yourself and no one watches you, and some have all parts on the shelf or employees will pull the part while you wait at the counter. Sunday was 1/2 price at one help yourself yard so windshields were $20, but I had no way to remove one.
I thought about cutting a hook in a hacksaw blade and adding a wooden handle. I guess I could develope something at home and practice on the broken windshield in the truck. Or get some of stainless steel braided wire and practice with that.
MSM
06-04-2007 01:37:08
If you don't want to buy the tool,get 3-4 feet of piano wire cut into 1 foot lengths.Takes 2 people to do it,but work it through the sealer and then work it back and forth like a saw and it will cut the sealer. This works real well especially if there is alot of excess sealant around the window,and it lessens the chance of cracking the windshield if the tool slips.
Bob
06-03-2007 22:01:56
Here's a couple of options:
Link
Link
I haven't dealt with this company, just used their site for illustration.
I have a tool like the second one shown. It doesn't work as well as the air-powered version used by the "pros", but it does work.
Third Party Image
Keith-OR
06-06-2007 22:08:44
 Re: Windshield Removal tool in reply to Bob, 06-03-2007 22:01:56
Bob, I have one like pic you posted except mine is electric heated and it melts as it cuts the urethane. If you are carefull can remove glass without chipping, cracking or bracking windshield.
The wire takes two people to operate, and it always seems to be my luck everyone was busy when I needed to cut one out!! :>(
Keith & Shawn
Joe(TX)
06-04-2007 05:42:52
That tool is ok to get a windshield out that is bad. If it isn't broke when you start, it will be when you finish. Use the music wire if you are trying to reuse the glass.
Bob
06-04-2007 06:40:44
 Re: Windshield Removal tool in reply to Joe(TX), 06-04-2007 05:42:52
If you look at both links, you will note I included a link to the "wire-type" tool.
NO guarantee of always getting the glass out in one piece with that one, either.
