Tool Talk Discussion Forum
XROGERX
MF294-4
06-03-2007 19:34:29
From my previous post and pictures of my air compressor, the tag on the tank has a serial no that starts with a 22xx, doesn't seem to have anything to do with the pump. The tag on the pump which is held on by three rivets on top and three on bottom and slid inbetween them. It has DB15P on it. I can't find anything with a 65 in it. If it is a Webster 65,do you have any specs.In your opinion, is is worth spending any money on? You can roll it over by hand and put some pressure in the tank. Where did you say I could get parts if I need any? Did you mean Webster went out of business in the 80s.
XRogerX
06-05-2007 20:16:01
 Re: XROGERX in reply to MF294-4, 06-03-2007 19:34:29
I was scouring old photos tonight and found this. It might help you out some.
[IMG]http://i31.photobucket.com/albums/c355/macmcmacmac/ScannedPhoto-2-8.jpg[/IMG]
XRogerX
06-05-2007 20:20:13
 Re: XROGERX in reply to XRogerX, 06-05-2007 20:16:01
third party image
Third time lucky..... how embarrassing.....lol
We could use an edit button on this forum!
XRogerX
06-05-2007 20:27:30
 Re: XROGERX in reply to XRogerX, 06-05-2007 20:20:13
From the photos, it looks like yours might actually be a model 60. The serial number, or a bore measurement should tell you for sure. The flywheel diameters are different, but that might not be an exact method, since flywheels can sometimes be swapped. When I said the company went belly up, I meant Webster, not Compresseurs Quebec, who are very much in business.
XRogerX
06-05-2007 20:29:44
 Re: XROGERX in reply to XRogerX, 06-05-2007 20:27:30
No, I think yours is a 65, judging by the side the intercooler is on. The Model 60 in the manual has no unloader on the back, like your machine, which threw me for a second.
XRogerX
06-05-2007 20:16:58
third party image
Ahem..... let me try that again....
XRogerX
06-04-2007 09:34:24
I believe the serial number is stamped into the crankcase, near where the block goes on. This is a fairly old machine, so they may have used a different numbering scheme back then. The tag on the tank will give you the year it was made, it doesn't relate to the pump in any way.
It was a very good compressor, but it is 40+ years old now. Parts should be readily available, but I'd be tempted to run it as is until it broke, since parts can equal the price of a new machine pretty quickly if anything major needs replacing. If you are feeling adventurous, you could pull the cylinders and check the condition of the small ends, since this was the main weak point in these machines, as in many compressors. If it is making good pressure, I'd leave the valves alone. I'd be most concerned about the tank, if you don't know how well it was looked after.
This pump should take up to a 5hp motor, and give about 16 - 20 cfm at the correct rotational speed. I wouldn't put much money into any compressor this old, simply because if you do, it would probably have been worth buying a new machine in the first place. I assume you got this one cheap enough? I got one for free a few years back and gave it to my brother in law. It was running a 2hp motor, and made a terrific home garage unit.
135 Fan
06-03-2007 20:59:09
I heard that some of the employees from Webster started a company to produce Webster parts. I think that's what XRogerX was referring to. Dave
