Tool Talk Discussion Forum
Pressure washer
JoeK(WI)
06-02-2007 19:34:02
Bought a PW last year,Honda powered 2600 PSI Porter cable.Noticed right away in manual"Never start engine without water source attached and turned on" and "Do not allow unit to run over 2 min w.o nozzle open"....Does this indicate this unit has no unloader?Is this possible?If so can one be added and where at?Engine begins to lug severely,opening governer when not spraying.
Leland
06-05-2007 21:03:31
 Re: Pressure washer in reply to JoeK(WI), 06-02-2007 19:34:02
try putting a weep style trigger handle on it this will allow some water thru and keep your pump somewhat cool
Greg_Ky
06-03-2007 08:18:20
Your unit has an unloader but must not be working properly. the reason they do not want it running more than two minutes without opening the trigger is because it builds excessive heat when it is in bypass mode. HTH
JoeK(WI)
06-03-2007 09:24:12
 Re: Pressure washer in reply to Greg_Ky, 06-03-2007 08:18:20
Kinda what I figured,as when starting it will almost instantly pressurize and kill cold engine and trigger must be pulled to relieve pressure for restart etc,real PITA,although seems decent unit once warmed and operating.Would almost be nice to have a manual bypass for starting/tuning.
PS:
-except that stiff plasticky hose has gotta go-
Greg_Ky
06-03-2007 09:46:47
 Re: Pressure washer in reply to JoeK(WI), 06-03-2007 09:24:12
Joe when you get it working properly again for what it is worth I always have run a small amount of RV antifreeze(cheap)through my pump after each use year around and have never had any problems with freezing or sticking valves. the washer I have will be twelve years old the end of July.
paul
06-03-2007 01:54:56
Spinning parts depend on water flow to cool them down - load wouldn't matter?
--->Paul
