Tool Talk Discussion Forum
power washer promblems
perry in mi
06-02-2007 02:02:02
what would cause my sears/craftsman power washer to instantly die when i let go of the trigger. it bogs right down and kills the motor. runs great if i have the trigger wide open at all times.
Mark/Ks
06-02-2007 18:37:35
 Re: power washer promblems in reply to perry in mi, 06-02-2007 02:02:02
I just fixed mine, but it was a Karcher. And yest it is an easy fix. Mine came out, and I added just a little white lithium grease, now works great...
Steve Crum
06-02-2007 15:58:35
Likely there is some corrosion in the valve behind the spring that is holding the valve in the closed position. Many of these can be taken apart and cleaned. You should have an exploded parts page in your manual that shows the valve disassembled.
Greg_Ky
06-02-2007 02:04:23
The unloader on the pump is not functioning.
oldrustycars
06-02-2007 11:41:18
 Re: power washer promblems in reply to Greg_Ky, 06-02-2007 02:04:23
What Greg said is correct.
perry in mi
06-02-2007 14:50:20
 Re: power washer promblems in reply to oldrustycars, 06-02-2007 11:41:18
is this a easy fix. and how do i go about it????? ?/
Greg_Ky
06-03-2007 10:00:55
 Re: power washer problems in reply to perry in mi, 06-02-2007 14:50:20
Perry, Remove the unloader/pressure regulator from your pump and clean it. Also for what it is worth I have always run a small amount of RV antifreeze (cheap) through my pump after every use year round and have never had any problem with freezing or any stuck valves and the pressure washer that I have will be twelve years old the end of July. HTH
