Tool Talk Discussion Forum
Pressure washer question
Brian in NY
06-01-2007 09:55:53
I have a small little pressure washer with a 3.75 Briggs engine on it. I purchased it from WalMart, it's a 2000 psi, not sure how many GPM.
It has a tube that you are supposed to be able to stick in a bottle of pressure washer soap/degreaser, etc and it will suck up the soap and spray it on with the water.
Well, mine doesn't work (doesn't suck up the soap), and never has. The pressure washer works great otherwise. I was hoping someone else would know what I am missing. I don't see any kind of valve to turn on the pump. Thanks in advance!
circus
06-01-2007 15:44:04
 Re: Pressure washer question in reply to Brian in NY, 06-01-2007 09:55:53
Ditto on the low pressure at the nozzel for the soap to flow. On my washer you need to pull the nozzel outward, or is it inward.
e
06-01-2007 10:16:44
Take the tip off your gun. It will only siphon if the pressure through the hose is very low.
tod
06-01-2007 09:59:52
Mine only works at low pressure for the soap feed - it requires a twist of the spray head -- My neighbors' requires a change of spray heads to use the soap feed.
