Tool Talk Discussion Forum
Pressure Washer question
dhermesc
06-01-2007 08:38:12
What would be the minimum PSI & gallons per minute that you would recommend for a decent pressure washer?
The car washers around here have all gone to low PSI systems (and low water volume) that doesn't seem much better then a garden hose. I figure if I can hold my hand 3 inches away from the spray tip it aint doing much.
RayP(MI)
06-01-2007 18:54:03
 Re: Pressure Washer question in reply to dhermesc, 06-01-2007 08:38:12
Mine"s 3200psi, 3.5 gpm. Like it a lot. Even cleans much baked on oil and grease off machinery. Loaned it to a friend, and he got a little careless, and cut the plastic trim on his car"s bumper cover. But there"s no substitute for pressure, flow when you need it!
circus
06-01-2007 15:50:42
Safer and better to just use a soft brush on a broom handle for the car exterior.
glennster
06-01-2007 09:53:47
kinda depends on what your washing. for general car washing, i'd stay under 2000psi washer. more than that and you can blow the paint, stripes and mouldings right off a car.if you are doing heavy cleanup , degreaseing, ect then go with a big one. i been wanting to get one of those steam cleaners, but i just cant seem to come up with a spare couple grand.
