Tool Talk Discussion Forum
clutch alignment tool for 8N Ford Tractor
Patrick Cullen
05-30-2007 07:23:10
I need a clutch alignment tool or advice on how to align the cluth to the pilot bearing. I could buy a clutch assembly which includes a plastic alignment tool but that seems a bit extreme. I need suggestions. thanks
cullen
cullen
06-02-2007 08:28:13
 Re: clutch alignment tool for 8N Ford Tractor in reply to Patrick Cullen, 05-30-2007 07:23:10
Thanks to everyone for their helpful advice. Dell, I took your suggestion and used the transmission shaft and replaced the seal. Worked like a charm.
Nolan
05-31-2007 03:49:34
You don't need a tool, just look at it.
If you feel the burning desire for a tool, make your own with a 3/8" extension and some masking tape.
A clutch alignment tool is not exactly a precision instrument.
old
05-30-2007 09:43:45
The tool Jerry has pictured can be found at any good auto parts store and the last on I got cost around $15. If you then take care of it the thing will last you till your grand kids grands kids have kids and then some
Dell (WA)
05-30-2007 08:28:06
Cullen..... ...iff'n you'd asked that question on the N-Board, we'd told you to remove the 4-bolt tranny input shaft to use that as yer clutch alignment tool. Simple, eh?
And while you have the tranny input shaft out, REPLACE the tranny input seal. $3 (cheap)..... Dell
JerryU
05-30-2007 07:48:09
third party image
See link
dan hill
05-31-2007 03:54:36
 Re: clutch alignment tool for 8N Ford Tractor in reply to JerryU, 05-30-2007 07:48:09
The transmission input shaft works much better.The ford car and truck input shaft will work fine.
rustyj14
06-04-2007 19:37:52
 Re: clutch alignment tool for 8N Ford Tractor in reply to dan hill, 05-31-2007 03:54:36
When i worked at the Ford Dealer, way back in 1948-51, we used the input shaft from a tranny, one that had been replaced because of missing teeth! Gee, i might still have it in my outback garage tool box!
