Tool Talk Discussion Forum
Cleaning out well
Eddie Jones
05-28-2007 18:34:24
I got a well it has tile in it. How would you go about cleaning it out. Do they have or make tool or a machine for cleaning them out. It was a well that was used for our house but we have got a water system now. I was just thinking of cleaning it out so I could use it to water the garden. Thanks Eddie
Sam#3
05-29-2007 19:39:59
 Re: Cleaning out well in reply to Eddie Jones, 05-28-2007 18:34:24
I'll also ask, "what are you cleaning from the well?" If silt and washed in sediment thats not too difficult, just dirty. If its bigger stuff like gravel then watch the stability. The walls may be washing out behind the tile. How much water is in the well and how much do you expect to be standing in when the muck is gone? Lastly, how large is the tile? The well at our old house was tiled with something about thirty inches. The 'Old timer' who had cleaned the well said the only way to work in something that small was with a cut-off shovel between his knees. Whatever you decide BE CAREFUL, get plenty of help, a good windless and check the rope. The guy in the hole does not want a bucket of muck dropped forty feet on his head.
Dave Anderson
05-29-2007 17:14:24
The thing to look for in these old wells is evidence of imminent collapse. How are the walls lined? If with brick or tile, are the courses running straight and true? Any evidence of slippage? By slippage I mean does it look like the walls go all the way to the top of the well? The reasoning behind these questions is that frequently old wells were lined at the bottom with wood pilings driven into the soft mud. With time the wood rots out, allowing the walls to slide down, sometimes collapsing. If the well looks sound, you then have 2 choices as to how to clean it. 1. Tripod over the top, lower a man down with a scoop and a couple of buckets, (After having pumped the well as dry as you can get it). 2. We used a different method with some good results. What you need to find is a sewer cleaning contractor who has one of those enormous vacum trucks that sucks clogs out of stopped up sewers. How its done, is you pump the well dry as above, then lower the 6" vac hose down the well, and suck out the accumulated mud at the bottom of the well. Then they lower a high pressure water hose down and wash it, then they suck out the water and mud, and repeat the process as often as they need to to get the well to the original depth. They can actually dig the well deeper, and lower concrete rings down to line the new deeper bottom. The only problem we ran into was the local authorities, and regulators, who don't know how to classify this line of work, and who don't like dug wells anyway, so my advice to you is to do the work, and don't ask if you need a permit, cause if your local gov't is like ours, once you ask, you will pull a s**t avalanche down on yourself!
Coloken
05-29-2007 05:58:15
The standard tool for cleaning out small, drilled wells is made from a pipe. It has a "flapper" valve on the bottom end, or like a plunger in the bottom that seals afer you stir it up and down to fill it. Easy to make with a welder. Bounce it up and down by hand (hard work) or with a winch.
rodgernbama
05-28-2007 21:02:05
How deep is the well? The old hand dug wells around here are around 30 feet deep. Oldtimers used to pump them dry and go down in them and clean them out.
2x4
05-28-2007 22:59:25
 Re: Cleaning out well in reply to rodgernbama, 05-28-2007 21:02:05
If you go down in them, there may be no oxygen & you will pass out. Nothing poisonous, just carbon dioxide. Lower a candle to the bottom. If it keeps burning you have enough oxygen. If it goes out, take a fan & direct air down it.
Super Steve
05-28-2007 19:11:35
what do u mean by "cleaning it out" is it contaminated or does it have "solid" contaminates in it?
Eddie Jones
05-29-2007 15:48:03
 Re: Cleaning out well in reply to Super Steve, 05-28-2007 19:11:35
The well hasn't been use in about 42 or 43 yrs. I thought I would clean it out to use to water my garden. Dad say the well is 27 or 29 feet deep and has 3 feet tile in it. Thank Eddie
Super Steve
05-29-2007 19:23:20
 Re: Cleaning out well in reply to Eddie Jones , 05-29-2007 15:48:03
if your just using the well to water the garden, just throw a pump in it but leave it high enough that it doesnt suck anything up.
