Tool Talk Discussion Forum
Roybi weed eater
BillD1
05-28-2007 13:16:08
My son was down today helping me clean up the place sometimes referred to as preprince Sleeping Beautys castle. Flower beds and odd spaces had gotten out of hand last summer when I was laid up with heart problems. His weed eater would only run about half speed. Gas was fresh and it might have been running rich. He said this was the first time he has had any problems and the machine is only a year or so old, Any suggestions for a cure ? Thanks BillD1
1945 A
05-30-2007 12:20:06
 Re: Roybi weed eater in reply to BillD1, 05-28-2007 13:16:08
I gave mine away----for not starting or running poorly when it decided to. The guy I gave mine to said that all he did was clean the air filter----not sure about that, but he swears it"s still running.....
MapleStone@work
05-29-2007 08:48:09
If it's the same as the one I had, don't bother trying to adjust the carb. The carb is factory set and you can't adjust them.
I had problems with the gear head on mine and after getting it fixed I sold it and bought a Stihl. Wasn't very happy with the Ryobi.
Ryobi hand tools seem OK but their lawn/garden stuff didn't impress me.
VernMI
05-29-2007 08:40:19
Also check and or replace the fuel filter on the end of the hose in the tank. It is about $6 for the tubing and filter kit.
Eddie in MI
05-28-2007 17:45:21
Another vote for cleaning your spark arrestor. And, while you're at it, make sure that your carburetor adjustments are correct too.
oldrustycars
05-28-2007 16:41:02
I'll second the spark arrester, although if the guard has been removed the line can be too long, which will also bog it way down. If its smoking and running rich, i'll lean more to spark arrester. I believe these run on 50:1, and always use the pre measured oil bottles, with exactly one gallon of gas. I have a cheapo Ryobi, used extensively for 7 years with no trouble. In fact only changed the spark plug once.
Greg_Ky
05-28-2007 14:47:48
Check the spark arrester screen in the muffler. Clean the carbon out of the screen and try that first.
christman
05-28-2007 15:07:18
 Re: Roybi weed eater in reply to Greg_Ky, 05-28-2007 14:47:48
check string length to long will bog one down
