Tool Talk Discussion Forum
Broken tap removed finally.
unioncreek
05-28-2007 08:49:24
I finally got the broken tap removed from the hole. I used a 1/8 inch pin punch and kept tapping away at it until I had one flute broken loose all the way through. Then the rest were easy. I then drill and retapped to a larger size.
Thanks for all the good ideas though.
Bobg
Slowpoke
05-30-2007 01:26:45
 Re: Broken tap removed finally. in reply to unioncreek, 05-28-2007 08:49:24
I believe it's best to keep the original thread size by using a Helicoil or similar insert. That way you don't have to enlarge the hole in the part to be mounted.
slowfolk
05-29-2007 05:47:11
If you by any chance you break another tap and you can"t remove it by your past methods, find a machine shop that has an EDM Machine and they can remove the tap for you. May be a little expensive but may save your part for you.
dan hill
05-29-2007 02:36:19
Dull taps break often.Cheap taps should not be used.Use a tap wrench and reverse the tap often to clear the chips.I have seen taps with a groove ground into the shank.This is supposed to make the tap break at the groove.
MarkB_MI
05-28-2007 19:51:22
Thanks for posting your results. It's always good to hear what did or didn't work.
oldrustycars
05-28-2007 16:43:29
You need to go buy some lottery tickets....you got lucky. glad it turned out.
RayP(MI)
05-28-2007 17:27:54
 Re: Broken tap removed finally. in reply to oldrustycars, 05-28-2007 16:43:29
Been there, glad you got lucky. Not an easy situation!
